Thread: Clunking noises?
    Regular Member mishima's Avatar
    UK
    confused Clunking noises?
    Hi there,
    I've been having some problems with my Vectra C for a few weeks now and It's becoming quite a headache. I've just replaced the pads as they were very badly worn and needed renewing. Now I hear clunking noises from the rear of the car (driver side rear). This noise is intermittent and can happen when I'm just driving down the road or when I'm going round a corner. We've taken the pads out and checked they are not moving about etc and they seem fine and checked for anything thats loose and can't seem to see anything.
    Does anyone have any ideas what this could be?? It's been suggested to see if the trailing arm or anti roll bar needs changing.
    Thanks!
    Maida Vale
    Does it sound like someone hitting the chassis with a small hammer... a "clunk" or "twanging" noise? If so, the two most common causes are anti-roll bar links (not the anti-roll bar itself) or the spring(s) jumping in its seat. Had it until recently on my wife's Signum (from all 4 corners) and had the anti-roll bar links replaced to no avail, so had the "spring seat mod" done which has fixed it. Basically GM came up with the idea of wrapping plastic sleeves around the bottom of the springs to cushion the blow when the spring jumps and hits its seat/pan. There are quite a few threads on it, GSi3.2 is an expert on it if you need further advice. Here's one thread on it:
    http://forum.vectra-c.com/showthread.php?t=57347
    West
    As said on the other forum matey, arb links, springs or upper arms are common.
    If it's coming from the rear.. i'd strongly suspect the top arm's outer bush is shot..it's a common fail point, much like the vectra B's..
    UK
    Replaced the front drop links today - one's that go from the anti roll bar to the suspension strut. Cost me £23
    My dad seems to think the noise was coming more from the front of the car. Going to take it for a run tomorrow and see how it goes, will let you know!
    Thanks for all the advice so far!
    Regular Member addyboy1982's Avatar
    Northampton
    As Mark says it's a common fault, had mine replaced now feel much better with no noise either
    preston
    http://forum.vectra-c.com/showthread.php?t=55484
    If the clunking still persists, have a look at this area of the car, the rear anti roll bar, crawl under the back of the car, grab hold of the bar and see if you can find movement. Not saying its the answer but worth a try, it worked on mine
    UK
    Thanks.
    Well, it seems the problem has been sorted. Been over 20 miles in the car today, across various roads at different speeds and had no clunking noises or anything.
    Thanks for all the advice!!
  1. Bird noises
    By nikroc in forum Suspension, Wheels & Brakes
    Last Post: 16th August 2011, 09:04
  2. 3.2 gsi noises
    By noudder72 in forum Engine & Drivetrain
    Last Post: 2nd February 2011, 19:05
  3. Front End Noises
    By a18nmk in forum Suspension, Wheels & Brakes
    Last Post: 20th December 2010, 20:53
  4. Odd noises..?
    By bigdave1701 in forum Vectra C / Signum Car Chat
    Last Post: 26th May 2010, 22:36
  5. Knocking noises - Help!
    By mishima in forum Vectra C / Signum Troubleshooting
    Last Post: 8th May 2009, 09:19
