Results 1 to 10 of 20
Thread: Shaking 3.2?
    Regular Member jamesr's Avatar
    Lancashire
    Default Shaking 3.2?
    I have a intermittent fault.
    At constant motorway way speeds the car starts shaking almost like you have a flat tyre?
    It shakes/vibrates violently.
    Not sure what it is ?
    Could it be the gearbox/bearings etc?
    Brakes and wheels are fine all balanced etc
    Regular Member glynn's Avatar
    stevenage, hertfordshire
    could well be the diff bearings m8 best get them checked out asap
    Lancashire
    How easy a job is this then?
    I can hear like a whirring noise from that area?
    Mileage : 000
    Does the vibration disappear when you dip the clutch, does it disappear when you accelerate or slow down.
    You say the brakes are ok, is there any vibration through the steering wheel.
    if it is the gear box diff bearings the take it to a gearbox specalist as it will be alot cheaper than the dealers
    Regular Member vectravirg's Avatar
    Bolton
    Don't know the answer but sure it was you heading up the A666 a couple of cars behind me in the outside lane near Asda on Thursday night, I just made it through the lights and you got stuck behind the car in front.
    If it was you, man those lights are bright!!!
    Had both my front wheel bearings go over the last few months, didn't get any of the judder you refer to but definately got the whirring noise.
    Lancashire
    Quote Originally Posted by vectravirg View Post
    Yes it was me about 6.15?
    My lights are bright 8000k HIDS
    Lancashire
    Quote Originally Posted by ed taylor View Post
    There is vibration through the steering yes, but also thewhole car vibrates.
    Stops when I slow down, if I pull over and set off again it stops.
    Dipped clutch/coasting still does it?
    Yet came home tonight at an average 75-80 and it was fine
    Quote Originally Posted by jamesr View Post
    someone else had this problem but i cant think who it was and what the out come was
    Mileage : 000
    I am wondering if you have a seized brake caliper. Is one whell very hot when you get home??.
  1. Car / engine shaking
    By old cruiser in forum Vectra C / Signum Car Chat
    Last Post: 15th June 2016, 19:14
  2. Engine Shaking the whole car
    By inchy1981 in forum Engine & Drivetrain
    Last Post: 17th December 2012, 14:34
  3. Odd shaking - Am I going mad
    By Tim525 in forum Engine & Drivetrain
    Last Post: 5th February 2011, 17:31
  4. shaking whole car
    By alijlacy in forum Troubleshooting
    Last Post: 15th December 2010, 17:20
  5. shaking at idle
    By POAH in forum Engine & Drivetrain
    Last Post: 19th December 2006, 08:10
