Thread: 03, 2.2 sxi Cat Conv fail or other issue at stake ?
    Aberdeen
    Default 03, 2.2 sxi Cat Conv fail or other issue at stake ?
    Good day folks.. looking for some neutral input here....My Vectra C 2.2 sxi running great... goes into dealer for ann. service it has done 44K miles (passes all checks etc). post service engine started misfiring, Eng Mgmt Light lit, dealer replaces spark plug, seems to be ok for a day then starts misfiring again but does not happen all the time so after 2 further weeks running the engine finally seemed to be in limp mode ?, had reduced power, uneven idle and also seemed to be running hot, I had hot fumes coming from engine at traffic lights. Left car with Vauxhall dealer again to be told that it needs mainfold/cat part but there are none in the UK ! (this was 3 weeks ago).
    When I asked why the Cat would fail after just having had it's annual check etc the response was "they can fail anytime." I am not so sure and feel there may be another fault causing the Cat to fail, the dealer and Vauxhall Customer Care have a 'don't bother me attitude' when I question that or even ask for a courtesy car !! (I am having to hire fm 3rd party). I was going to replace the car with an 08 model but now I am having 2nd thoughts about buying another Vauxhall, esp as they cannot seem to supply a spare part for one of the most driven cars on our roads ! .... am I being paranoid ?, should I just take my car out and have Kwick Fit do it !!
    Northampton
    Engine : A20DTH
    Mileage : 88000
    Mass air flow meter, cause the car to over fuel and burn out the cat. Usuallly burns out a sensor or too as well.
    Aberdeen
    Thanks merikiito... I'll check that out. Would have thought that a Vauxhall main dealer could have advised same !
    Regular Member rushy's Avatar
    Vehicle : 9-3 Wagon
    Trim : Turbo Edition
    Engine : TID (1.9 16v)
    Year : 2010
    Mileage : 137000
    Vid had similar problems, turned out to be his Lambda sensor, the one before the cat.
    Aberdeen
    rushy.. thanks as soon as get the car i'll post the results, in the meantime I have raised a "case" with Vauxhall Customer Care centre regarding the non supply of parts and also the indifferent attitude of the vauxhall dealer t my plight
    Aberdeen
    Final results... got fed up waiting for VX to supply Maniverter after 5 weeks so bought used one from a 54 plate w/ 34K miles (Premier VX spares Plymouth) had dealer fit but STILL misfiring, dealer then informed me that the "Spark Rail" was faulty and they had tried one from another car and all was OK... so... had a new spark rail fitted but the dealer is adamant that the CAT had failed (collapsed ?) Dealer is adamant that they could not have forseen the ignition fault BUT say this could have caused the CAT to fail. Needless to say after all this time and now 430 quid out of pocket I will not be using that dealer again.
  1. HELP With M.O.T FAIL!
    By corderz in forum Vectra C / Signum Troubleshooting
    Last Post: 25th May 2011, 09:23
  2. Mot fail
    By justyb in forum Vectra C / Signum Car Chat
    Last Post: 15th May 2010, 14:36
  3. Mot Fail
    By Cam in forum Engine & Drivetrain
    Last Post: 8th February 2010, 23:11
  4. Gear Box Tourqe conv. issues
    By Ean in forum Vectra C / Signum Car Chat
    Last Post: 27th October 2009, 23:25
  5. Will it fail an M.O.T ?
    By The Gas Man in forum Vectra C / Signum Car Chat
    Last Post: 8th November 2007, 00:14
