Results 1 to 10 of 15
Thread: Stereo Install driving me mad!!!!!
    Yateley, Hampshire
    Default Stereo Install driving me mad!!!!!
    I can't find my original thread on this but there was a real helpful member that answered my first question regarding this ignition feed but i'm still stuck and trying to avoid a large bill (£65) to install the stereo.
    Sony headunit with quad to iso in place but dead stereo so i'm told there is a black wire to connect to by the ciggy lighter.
    As from the pic all i have is the l shaped connector on the cig lighter and two grey/yellow plugs floating in the wind, am i looking in the right area??
    Ely, Cambridgeshire
    61 Post(s)
    Vehicle : Insignia Tourer
    Engine : 2.0 CDTI (160ps)
    Year : 2010
    If what you're after is an ignition feed, take it from the black wire on the plug that's connected to the bottom of the cigarette lighter.
    Jul 2006
    Somerset
    You need to connect your switched live from the stereo into the black wire coming from the ciggy lighter - which you can see in your picture.
    EDIT
    Kent
    Vehicle : Fiat
    Trim : Panda 100HP
    Engine : 1.4
    Year : 08
    Don't forget you have to sometimes swap the red and yellow wires on the radio loom.
    Regular Member rushy's Avatar
    Vehicle : 9-3 Wagon
    Trim : Turbo Edition
    Engine : TID (1.9 16v)
    Year : 2010
    Mileage : 137000
    Your original thread HERE mate. As Tyreman said you will need to swap the red and yellow wires around. I just did it at the in line fuse connectors. Put the red female on the yellow male ad visa verse.
    Larkhall
    Yep, take your switch live from the black cable mate. That's the worst thing about full canbus....... Half canbus are easy to change as you have no quadlock or live feed to get lol
    Vehicle : 9-3 Wagon
    Year : 2010
    Mileage : 137000
    Mines half canbus and I had to take a live feed from the ciggy Tam.
    Yateley, Hampshire
    Members
    I cannot thank you enough for the responses already. Gutted as this morning the missus has taken the car to do some shopping and i'm desperate to get out there and try the connections.
    So to get this right then i have two loose wires (red and orange) coming from the quad adaptor, i then have a red and yellow connector coming from the stereo iso lead, so is it the red from the stereo iso to the black connector as i'm sure i already tried the red from the quad on that black wire and no joy.
    As ever thanks for your help gang,
    Surrey
    Red is normally switched live on pin 7 of the iso.
    Yellow is constant 12v pin 4 of the iso.
    Sometimes these are switched.
    On the top of your old stereo should be the pin outs. You need to find +12v and follow in into the +12v constant of the stereo. I suspect it is unconnected hence dead stereo.
    Then find the switched +12v on the stereo then they are saying connect the bullet connector to the ciggy lighter as this is switched. This will turn the stereo on/off with ignition.
    Yateley, Hampshire
    Gang, you're all top dogs!
    Missus finally came home, managed to get into the car and try connections as suggested...bingo, what a difference an aftermarket unit makes to the factory fitted unit.
    I'd like to say that your advice saved me money, it did, however the missus has just blown next months budget on clothes that'll be worn once then look good in the cupboard........so much for me trying to save those pennies.
    Cheers once again gang.
  1. want to install my aftermarket stereo
    By Slick_richie in forum Electrical & ICE (including SatNav)
    Last Post: 14th May 2012, 11:05
  2. stereo full install q's
    By jays_225 in forum Electrical & ICE (including SatNav)
    Last Post: 16th May 2011, 21:42
  3. Ex police stereo install?
    By Aaandyyy in forum Electrical & ICE (including SatNav)
    Last Post: 16th April 2011, 23:24
  4. Pics of my stereo install
    By Marc Hutton in forum Electrical & ICE (including SatNav)
    Last Post: 5th October 2008, 21:36
