Thread: Vx Software/Firmware ECU updates – 1.9 CDTI
    Wales
    Default Vx Software/Firmware ECU updates – 1.9 CDTI
    Does anyone know when (or even if) Vx release software/firmware updates for any of the ECU’s? Anyone got a current list or know when the last ones were issued? (either the 120 or 150)
    I see this as the only reason to go to the dealers for a service (I assume independents can’t update ECU’s).
    they release updates all the time...and if an independant has tech2 and the relevant licences thay can do the updates too..
    Wales
    Nice.
    How would you go about finding out if a garage is 'able' to do this? Of course, you could ask them and they'd say 'yes sir' but you would be none the wiser if theve done it or not..
    Can the car tell you what version(s) it is running (and importantly can, Vx tell you if there are updates availbile?)
    Regular Member old cruiser's Avatar
    slough
    Quote Originally Posted by snapsnap View Post
    Nice.
    Found on mine that if I press the speedo trip button and hold it for several seconds it comes up with some numbers (not mileage to next service) that look like they could be a software version number, could try it on yours and see what happens and if the same give VX a buzz to verify.
    Cheers Pete
    thats the software version for the instruments, nothing else..
    SnapSnap,
    there's no way to tell, unless you have 'proper' diagnostic gear like OP-Com or Vauxcom or TECH2..thats the only way you'll see what versions it's running
    Regular Member VectraV6CDTi's Avatar
    Wilts
    Be careful as I've heard some software upgrades can "slow" your car down. Sometimes due to emmissions tweaks. I'd say leave it alone if its running fine.
    Jul 2006
    Northampton
    Trim : Sri
    Engine : 1.9 cdti 150
    how much do these upgrades cost?
    Administrator plasma's Avatar
    On the Forum
    404 Post(s)
    Engine : 150
    Mileage : 74000
    probably labour time only, so to you lot probably £50-90
    Regular Member luckyluke's Avatar
    May 2008
    S'port and L'pool
    Quote Originally Posted by VectraV6CDTi View Post
    I had my car's ECU updated due to my complaint it was a bit 'shaky' when on idle under a load (from air-con, rear windowd heating, etc.)... and now it is shaky even whitout any load . Not happy with it. As they say - best is the enemy of better - stick to what you have and you're happy about it
  1. Known software updates / field remedies
    By robster23 in forum Y & Z30DT Specific
    Last Post: 5th September 2013, 12:53
  2. Tech-2 & ECU software updates.
    By gtr1000 in forum Electrical & ICE (including SatNav)
    Last Post: 3rd December 2011, 10:53
  3. Software Updates
    By GenVectra in forum Vectra C / Signum Car Chat
    Last Post: 10th February 2009, 14:05
  4. op-com software version for 1.9 CDTI
    By Marco_ita in forum Electrical & ICE (including SatNav)
    Last Post: 4th August 2008, 17:28
vectra c 1.9 ecu update
2007 vectra 1.9 cdti ecu update
soft do opel vectra 1.9cdti
software update signum 1 9 cdti
vectra c 2 2 firmware ecu
