Results 1 to 10 of 30
Thread: Car Kit
    Regular Member scott_150cdtisri's Avatar
    Jan 2006
    Crewe
    Default Car Kit
    hey all not been on a while i am wanting to get a car kit for my phone and just wondered if anyone has done much research in this. i have the cd 30 so because of the stupind connecters i dont know if u can get one to go through stereo, i have a samsung d500 by the way so i imagine it will be a bluetooth kit id want
    cheers scott
    Regular Member Damian's Avatar
    Market Drayton
    I had a Nokia CK-1W (I think) bluetooth car kit in my car with the CD30. Guy that installed it had it running through my CD30 stereo as there should be a handsfree connector behind the glovebox to the right that he tapped into/used
    Jan 2006
    Crewe
    thanks damian i`ll have to look behind the glove box, has anyone else tried this what wires etc do i use, i have been told that the ones i should look at are the parrot/nokia or sony ericson kit
    Jan 2006
    Crewe
    i looked behind the glove box today and couldn`t see any connection is this something that is installed into all vectras or ones just with the factory telephone option
    North Bucks
    Hi,
    "Behind the glovebox" is perhaps a bit of a misnomer. What you're looking for is the 18 way VDA socket. If it's fitted it'll be taped up in the loom on the right when you take out the glovebox, high up just behind the display screen.
    If the VDA socket is there, it's plain sailing. You just need the relevant Autoleads cable to go from the VDA socket to your car kit. Install the kit, the phone holder and the mic and away you go. The connector supplies switch and permanent power, radio mute and speaker connections.
    I was lucky, the VDA was fitted to my car (2005 Elite with CDC40 system) so it was easy. The sound comes out of the front speakers and is adjustable with the steering wheel volume control. The screen displays "External In" while the phone is in use.
    Received wisdom is that if the CDC70 is fitted, the VDA sockets is always there, if it's CDC30 then normally not there unless specified as 'prewiring' when the car was ordered. CDC40.... well I found one.
    If the VDA socket isn't there you'll need a different Autoleads cable. As I understand it, remove the stereo and plug in the lead between the stereo and it's quadlock connector in the wiring loom.
    A great source of advice is www.siocommunications.co.uk. Have a look at the forums (old and new) because there is even a picture of the VDA connector so you'll know what you're looking for. Sio is run by a really helpful guy (Terry Wright) and his online shop sells the Autoleads & mounting brackets you'll need to do the job.
    No - before you ask I'm not on commission! Just a satisfied customer.
    Ashington, Northumberland
    Quote Originally Posted by Freefaller
    ....A great source of advice is www.siocommunications.co.uk. Have a look at the forums (old and new) because there is even a picture of the VDA connector so you'll know what you're looking for. Sio is run by a really helpful guy (Terry Wright) and his online shop sells the Autoleads & mounting brackets you'll need to do the job.
    I'll second that, the guy was great when I fitted my motorola bluetooth kit, and as stated above, if the VDA connector is there, it's like falling off a bike It's taped up with plain old masking tape if that helps you find it, top right hand corner.
    Jan 2006
    Crewe
    thanks freefaller and gary that has been a big help. as soon as that sun rises tomorrow that glove box is coming out. again!! it said on that website in there experience all vectra and astra sri`s have that plug so fingers crossed! ive been looking at the parrot car kit the one with the colour screen, is this a good one? the wife has the older 3100 version and she says it is good to use and had no problem with it. cheers again
    scott
    Quote Originally Posted by scott_150cdtisri
    scott
    Couple of guys I know use the Parrot and they are very good from what I've seen, they can't fault them. I have a motorola kit (HFW8000), and it is a great bit of kit.
    Preston Area
    ive got a ck-7w bluetooth nokia setup in mine... used the vda connector and got the leads from siocommunications.... the guy that runs it is very helpful.. have look on the forum.. even without the vda connector it can be done quite easily
    Dec 2005
    Renfrew, Scotland
    Quote Originally Posted by bruceybonus
    can vouch for sio communications - top bloke, helped me out a good few times with varios leads for handsfree kits...
