Thread: washer bottle removal
    Regular Member Darryl2.2DTI's Avatar
    Oct 2007
    Kilmarnock, Ayrshire
    Vehicle : Vauxhall Vectra C
    Trim : LS
    Engine : 2.2 DTI
    Mileage : 106000
    Default washer bottle removal
    car failed its mot due the the window washers nor scooshing water. he says the bottle must be damaged as it leaks water when u try and fill it. how do u gain acsess to it. its on a 03 vectra c 2.2dti.
    any help would be great.
    cheers
    Regular Member John35's Avatar
    Jun 2007
    in a white box
    Turn the front wheels to the right. Remove the two front screws in the f/n/s inner wing to release the plastic inner wing. Pull the plastic out and you will see the washer bottle and the pump. Pump just pulls out. You can then pull off the two water pipes. The electrical connector has a clip. Bit of thought and it is easy to remove.
    I would imagine that the filter at the bottom of the pump is gunged up. Mine smelled like a sewer. But if you need a pump you have it in your hand.
    When you put it back make sure that its pushed back firmly so that it won't leak. Fill with water to check before putting everything back....
    Oct 2007
    Trim : LS
    Engine : 2.2 DTI
    Mileage : 106000
    top man. cheers
    Default Washer Bottle Problems
    Hi all, I am having a problem with my washer bottle - I have removed the motor and checked the pump all works fine - even managed to get get water out of the jets - I put it all back together and no water comes out. Do you think this may be a small sweage plant at the bottem of the bottle as well.
    Please be kind it is my first post on here.
    BTW its a 04 Signum 2.2 dti
    Regular Member LOCKSTOCK's Avatar
    SUFFOLK
    Check the rubber that the pump pushes into as it is a filter as well pull it out and clean the little holes in it.
    Jun 2007
    in a white box
    Quote Originally Posted by LOCKSTOCK View Post
    I'll second that pull the filter off and clean. clean the bottle as well since you have it all off. Check with a clean glass of water before putting back together. Probably just needs a good clean.
    Oct 2007
    Trim : LS
    Engine : 2.2 DTI
    Mileage : 106000
    Quote Originally Posted by John35 View Post
    il 3rd that.
    I'll 4th it. Just for some spam.......
  1. washer bottle
    By stret in forum Vectra C / Signum Car Chat
    Last Post: 15th January 2013, 16:13
  2. Washer bottle removal.
    By carperjake in forum Bodywork & Interior
    Last Post: 2nd July 2012, 11:00
  3. washer bottle removal
    By paul.sessions in forum Vectra C / Signum Car Chat
    Last Post: 4th July 2009, 10:29
  4. Washer bottle cap
    By mreeve99 in forum Vectra C / Signum Car Chat
    Last Post: 4th January 2009, 20:09
vauxhall vectra washer bottle removal
vectra c washer bottle removal
