Thread: Caliper modding (question)
    Strabane/Belfast
    Default Caliper modding (question)
    Really want to pain my Calipers but have no idea what to do, i had a look at them today and they didnt look too smooth. How did people on here do theirs? i only have a normal jack so im assuming it would take forever to do it
    Sunny Dartmoor
    Just clean them best you can with wire brush and some brake cleaner,once dry just give them 2 or 3 coats of hammerite smooth paint,should dry within an hour of painting,good luck.........
    Regular Member Deadman's Avatar
    earth
    I rubbed mine back with a sander using 180 grit removing the majority of the casting marks, degreased using meths, masked, coat of two pack primer. Once dry, applied 3 coats of two pack polyurethane and got a lovely deep shine.
    If you're doing at home however, you can't go far wrong with Glenboy's advice. Just make sure you take your time to clean them and remove any crap before you start painting.
    Regular Member Genterz's Avatar
    Herts
    They're really easy mate. Hopefully doing mine 2moz if it stays dry.
    The Hammerite paint (or proper caliper paint if u use it) will smoothen out the appearance of the calipers. It makes cleaning them a lot easier
    Strabane/Belfast
    cheers lads
    im not sure if ill do this one on my own, im not the best with a paintbrush!
    I really like the look of them tho so I'll need to figure something out!
    Jul 2006
    Northampton
    Trim : Sri
    Engine : 1.9 cdti 150
    its an easy job, i did mine like glenboy said, just make sure you mask anything you dont want painted.
    Strabane/Belfast
    does anyone have any picutures of this?
    before, after, during.....
    Jul 2006
    Northampton
    Trim : Sri
    i have after and i will soon be repainting the, so will have part 1 after, part 2 before during and after
    earth
    Just after I'm afraid and not a great photo at that:
    The world famous city ground
    Vehicle : Vectra cdti estate
    Trim : Get a
    Engine : Dirty diesel
    as stated above, brake cleaner and lot's of it, wire brush and plenty of elbow grease.....you can also use engine laquer @ about £5 a tin from a local car spare's place and dries realy quick, also heat resistant and avaliable in many colour's.....
    hth
    Midlands Mod Shop - NFFC.
  1. Caliper question
    By lizard in forum Suspension, Wheels & Brakes
    Last Post: 12th June 2011, 22:36
  2. Caliper carrier question
    By Derek Mc in forum Vectra C / Signum Car Chat
    Last Post: 21st July 2010, 17:42
  3. Question about signum caliper
    By turbosiggy in forum Vectra C / Signum Car Chat
    Last Post: 9th March 2010, 17:53
  4. Rear Caliper Question
    By HHH in forum Suspension, Wheels & Brakes
    Last Post: 14th August 2007, 20:57
  5. Brake Caliper Painting/Caliper Decal's??
    By BigMan in forum Vectra C / Signum Car Chat
    Last Post: 12th August 2007, 21:14
