Thread: Exhaust
    Regular Member Tim2100's Avatar
    Walsall
    Default Exhaust
    Is it worth putting a new back box or full exhaust on the 1.9 diesels?
    Is there any noticible improvements?
    Where is the best palce to go lookign for one? as i have never seen aftermarket performance exhausts for diesels?
    Tim.
    I can't imagine you'd get much more performance from an exhaust on a diesel. I changed mine purely for cosmetic reasons (big poser) and had it all done at Powerflow for £250 +vat.
    Full exhaust is always the way to go if its power you want the most restrictive part of modern systems is the catalyst do away with this and then put on a good after market system (or taylor-made) the choice is yours ......Of course you do have to make sure the engine can get more fuel and air in to start with so the panel filter and airbox mod or an induction kit should also be done at the same time then its time for a re-map or tuning box and a session on the rollers !!!HTH
    South Central England
    12 Post(s)
    Vehicle : Vauxhall
    Trim : very
    Year : Nosey
    Your car may well through a fit if you go for a straight through system Tim. I asked Vx before having the same as AJA put on and they said it would probably not run. Well it did run but it kept stoping. I put the centre box back in though keeping the twin rear exhausts with straight through scilencers and now it runs fine. No improvement in power though (wasn't any with the centre scilencer out either).
    So you would be just as well if it's cosmetic, saving the cash and just getting centre scilencer back.
  1. Exhaust hanger broken /rotted from exhaust.please help.
    By Dobs in forum Engine & Drivetrain
    Last Post: 25th January 2012, 21:06
  2. Duel exhaust - where to get a right hand exhaust heat shield
    By Innes in forum Bodywork & Interior
    Last Post: 29th November 2011, 00:47
  3. Fitting Dual Exhaust on single exhaust 2.2 sri
    By sdnatlst in forum Petrol Engine related
    Last Post: 1st February 2010, 10:49
  4. Where to buy oval exhaust tail pipes for signum exhaust
    By eaglepva in forum Vectra C / Signum Car Chat
    Last Post: 17th June 2008, 17:16
  5. Replies: 7
    Last Post: 22nd August 2007, 21:16
