Page 1 of 4 123 ... LastLast
Results 1 to 10 of 34
Thread: How Long to heat Up for a 1.9CDTi?
    Regular Member boba's Avatar
    The Kingdom of Fife!
    Default How Long to heat Up for a 1.9CDTi?
    My first Vx diesel so don't know what to expect here. 1.9CDTi seems to take quite a few miles to get to working temperature. About 12 miles easy driving before the needle settles at 85 or so. Is this normal? How long does yours take?
    Regular Member MattW's Avatar
    Sheffield
    Mine varies depending on the outside temperature as well.
    If it's cold, I can get to work (6 miles) before the needle has even moved from it's resting place. If it's warm outside (say 14degC +) it takes about 3 miles to start warming up.
    Wouldn't worry about it much mate, all diesels take a while to warm up. Whel driving in freezing tempeatures and coasting down a hill, I've gotten the needle back off the scale again...
    And when I lifted up the bonnet, the engine cover was cold to the touch - and this was after 100 miles of cruising...
    Regular Member Ste's Avatar
    ..... Driving the Jaguar XF
    Vehicle : Jaguar XF 3.0D V6
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    Normal, and due to the large thermal mass of the engine, and heat transfer to cylinder walls.
    Petrols generally warm up quicker due to the lighter engine, using materials with a lower specific heat capacity.
    I guess it's OK then . It was kinda chilly here this morning (3 degree warning on the display).
    Quote Originally Posted by boba View Post
    You lucky lucky bast.........
    Feb 2006
    Guttedsville
    Quote Originally Posted by Penfold101 View Post
    Mine did that going down the A20 into Dover during the summer, it was a goosed thermostat.
    Mine generally takes between 3-4 minutes of running before the needle moves up to about 80.
    Regular Member Ian S100's Avatar
    Mar 2007
    Southport
    When you're coasting down a hill the fuel supply probably shuts off all together to improve economy so it won't be generating any heat.
    If you're in gear then I htink it does shut it off (overrun) but I was in neutral so it would have to fuel the engine or it would stall I'd have thought...
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    Friction would still generate heat, probably more than idling would generate
  1. Replies: 18
    Last Post: 15th August 2012, 20:36
  2. How long to heat up?
    By woodspsx1 in forum Engine & Drivetrain
    Last Post: 31st January 2011, 08:11
  3. How long do glow plugs normally take to heat?
    By cont1204 in forum Vectra C / Signum Car Chat
    Last Post: 5th October 2010, 14:02
  4. how long do cambelts last on a 1.9cdti 150 (signum)
    By bangty 1 in forum Vectra C / Signum Car Chat
    Last Post: 3rd October 2010, 20:04
  5. Induction kit for 1.9CDTi 150 (Z19DTH) with a heat shield?
    By WooSAABy in forum Vectra C / Signum Car Chat
    Last Post: 23rd December 2008, 23:10
vectra c 1.9 long warm up
z19dth warm up
