Results 1 to 10 of 20
Thread: Lowering springs & camber adjustment
    Regular Member DTGB's Avatar
    Basingstoke, Hampshire
    Default Lowering springs & camber adjustment
    I am thinking about lowering my 2.2 veccy(non SRI), (with eibach springs from LMF) but I am worried that this will change the camber & scrub my tyres, thus ballzing up the handling etc...is this true and what do I need to stop this?
    Cheers in advance
    West
    Once the lowering springs are on, you need a full four wheel alignment.
    Mines being done tomorrow...
    Cheers for the quick reply - would a normal garage/tyre centre do this, or do you have to take it somewhere specialist?
    Good luck with the fitting & set up ;-), let me know if it makes a big diffrence or not - which springs have you bought?
    West
    Only if they have a proper 4 wheel alignment system, a lot of people on here recommend the hunter system, if you search for it you will find a link for a site which can locate the nearest to you (alignmycar.com or something)
    Mine is being done by a friend of mine local to me who specialises in building race cars & tuning evo's subs, & skylines etc...
    He is also responsible for building apex tunings drift car (yellow skyline) and controversially put a yank n/a V8 in...
    West
    Quote Originally Posted by DTGB View Post
    Thanks...
    I have gone for the apex -35mm drop...
    Tyneside
    I got camber adjustement bolts to allow for it to be set up slightly more, but as already said get it alligned on a hunter system and you can't go wrong even though it isn't cheap.
    the site to use to find your local centre is www.alignmycar.co.uk
    it's not too dear ( Big phils was done at my mates place ( 4 wheel alignment and 4 camber steetings) for £50 on an invoice) but it makes all the difference to the car and your tyres...lowering without setting the car up is only 1/2 a job..
    Thanks to you guys for the help, so in short - if I get the springs fitted, and invest in set of camber adjustment bolts, & then visit my local 4 wheel alignment centre, I would be good to go?
    West
    yep, but why not have a word with the alignment guys first & see if they will fit & align all in one go.
  1. Camber adjustment?
    By Neil07D in forum Handling & Braking
    Last Post: 22nd January 2012, 11:20
  2. Front camber adjustment?
    By Tayla in forum Handling & Braking
    Last Post: 13th November 2010, 14:01
  3. Rear Camber Adjustment
    By spoons in forum Handling & Braking
    Last Post: 10th November 2010, 22:00
  4. Camber adjustment bolts
    By Danwells72 in forum Vectra C / Signum Car Chat
    Last Post: 18th January 2010, 09:23
  5. camber adjustment
    By hagga in forum Handling & Braking
    Last Post: 12th November 2007, 15:45
