Thread: Water Pump/Coolant
    Regular Member barkzz's Avatar
    Default Water Pump/Coolant
    Hey Guys,
    Just a quickie, i've had my water pump replaced as discussed in another thread. (Sticking bearing, causing an horrendous racket that sounding like the camblet tensioner about to snap )
    This is on an 03 1.8 SXI, so cambelt etc. all had to come off.
    The garage, mentioned that this could have been the cause of me having to top the coolant up more regulary than usual?? Could this be the case?
    I have also had problems with my temperature gauge giving wierd readings, but since the water pump has been done, the temp guage is back to normal, and the cooling fan cut's in at around 85-90, and the engine is definately running at a more sustained temp, as proven by the warm bonnet after a 15 minute journey.
    Could this have also been solved since having the pump done, or is it just coincidence??
    Full Member Big Sig's Avatar
    Why not. It could have been leaking water from the pump and its now circulating the water around the engine better
    yep, it could well have been the cause of the coolant loss... when the pumps bearings go, the gland seals take a hammering, so often let coolant weep past..it would have shown up as a reddish stain on the old pump...and if it had suffered the other waterpump problem ( corroded or broken impeller) then it would really affect the temp in the way you describe...
    sounds like an allround result for the cost of a pump and fitting..
    Yes definately,
    Running much better now without any shadow of a doubt.
    And the best bit...Got it sorted through an independant who i know for £45!!!
    He's a decent bloke and is an old school mechanic, not like some of the vauxhall "laptop" technicians of this era!
    Thanks guys.
  1. Water, Coolant & Heater Problem
    By tris_hill in forum Vectra C / Signum Troubleshooting
    Last Post: 28th March 2011, 14:24
  2. Water for coolant?
    By goafer in forum Engine & Drivetrain
    Last Post: 22nd December 2010, 23:02
  3. water coolant temp sensor....
    By bertiecbx550 in forum Vectra C / Signum Car Chat
    Last Post: 30th October 2010, 13:54
  4. Coolant Leak, Water Pump?
    By rsocon in forum Engine & Drivetrain
    Last Post: 22nd December 2009, 21:46
  5. Advice/Info Needed - Losing Water/Coolant
    By ChrisBilly in forum Vectra C / Signum Car Chat
    Last Post: 2nd November 2009, 18:20
vectra c 1.8 coolant leak on water pump
