Thread: Diesel Smell
    guildford
    Default Diesel Smell
    Ive got a intermittant smell of diesel from my vectra. I've fitted a new filler cap, which seemed too cure it for a while,but now it's doing it again. Are there any good after market locking caps on the market?
    North Bucks
    Where's the smell, on the outside or inside the car? Coming through the air vents?
    Give us a clue!
    Jul 2006
    Northampton
    Trim : Sri
    Engine : 1.9 cdti 150
    i would assume outside as its the filler cap
    guildford
    Defenitly Outside.
    Jul 2006
    Northampton
    Trim : Sri
    probably not got a tight seal on the cap check it out and maybe replace it. if its not that then you may have to look at the filler pipe and fuel tank. that is worst case, again if its not that then take it to a garage to look at.
    Jun 2007
    Black Country
    make sure the area around the filler cap is cleaned, put some gaffer tape around the filler door for a day or so and see if the smell still exists
    guildford
    Should The Filler Cap Hold Pressure In The Tank?
    Jun 2007
    Black Country
    yes im pretty sure it does, if you let your fuel run low, then goto fill up, you usually get a pressure hiss when you remove the fuel cap
  1. diesel smell
    By chris1804 in forum Troubleshooting
    Last Post: 3rd November 2011, 22:45
  2. Diesel Smell When Warm
    By Si-SRI in forum Vectra C / Signum Car Chat
    Last Post: 18th April 2011, 14:42
  3. Diesel smell
    By ed taylor in forum The 'Off Topic' room
    Last Post: 26th January 2009, 21:14
  4. Diesel Smell Inside Car
    By BigKev1970 in forum Engine & Drivetrain
    Last Post: 26th April 2008, 22:16
  5. Strong Diesel Smell
    By DeathStar in forum Diesel Engine related
    Last Post: 2nd December 2007, 16:54
