Thread: CD70 NAVI No Sound - Squealing Noise
    Oct 2007
    Cov
    Default CD70 NAVI No Sound - Squealing Noise
    Hi, anyone any ideas what the fault is here?
    I have a CD70 NAVI and yesterday it packed up and all you hear is a high pitched tone/squeal through the speakers when listening to either radio or cd, or using the phone. The Navigation does work however...
    I've tried disabling bluetooth, removed the fuse etc, but fault still exists?
    Is there a way to do a reset of the system?
    Oct 2006
    Wellingborough
    If you run the upgrade CD it will do a full reset of the unit, and -may- cure the problem.
    Oct 2007
    Cov
    Quote Originally Posted by Flaninacupboard View Post
    What's the update CD? I've only got the actual Sat Nav and the language CD? I've booked it in to the dealers Thur - its only 6 months old!
    11 Post(s)
    I believe the language CD is also known as the update CD. It's the disc you use to configure the CD70 the first time it's used.
    Oct 2006
    Wellingborough
    Ah if its going back to the dealer then dont bother trying anything yourseld, they will most likely just replace it with a new unit anyway.
    Oct 2007
    Cov
    yep, unit is stuffed - being replaced under warranty.
  1. squealing noise when turning right.......
    By jinkie in forum Suspension, Wheels & Brakes
    Last Post: 5th October 2012, 20:38
  2. Squealing noise from somewhere on the car
    By Hideous in forum Engine & Drivetrain
    Last Post: 1st February 2012, 18:25
  3. Squealing Noise
    By Hursty103 in forum Engine & Drivetrain
    Last Post: 8th October 2008, 18:00
  4. squealing/whistling noise
    By cholly69 in forum Engine & Drivetrain
    Last Post: 30th August 2008, 08:29
vauxhall zafira sat nav no sound
cd70 navi no sound
