Results 1 to 10 of 13
Thread: reverse sensors, light out, and blipping
    Essex
    Default reverse sensors, light out, and blipping
    Hey there,
    ive just fitted some reversing sensors from ebay, they work fine, but i have the old problem of the reverse light warning on dash, and the sensors are blipping.
    I connected both the live and earth to the reverse light wiring directly next to the plug for the rear lights.
    Ive searched on here, and read all the stuff on the problem, and realise the answer could be a by-pass relay.
    My queston is what are the options ? and is there another way of wring it up without the relay ? Does a normall relay not do the trick ?
    If i have no choice, wheres the best place for a relay ?
    Thanks in advance for any help..
    Mike
    member of the smoke patrol 230bhp+
    just put a relay inline and it will stop it for you
    Regular Member JuzzyD's Avatar
    Jun 2006
    Somewhere...
    I've not had problems with mine, I connected the live to the reverse light wire but wired the earth directly to the car body and not via the wiring loom - might be worth moving your earth wire.
    Sunny Dartmoor
    Surrey
    I wired mine to the reverse wire black and white from memory the one up from the bottom, bottom was empty and the brown earth wire. Mine works fine.
    Essex
    Quote Originally Posted by JuzzyD View Post
    Just done that as you said, and when i sussed the reverse bulb WAS actually dead, , lol
    all seems ok now...
    Mike
    Sunny Dartmoor
    Result....
    Surrey
    Quote Originally Posted by Mikeymate View Post
    all seems ok now...
    Mike
    Always check the obvious first...lol.
    Regular Member 67688c's Avatar
    Apr 2008
    In UK
    all seems ok now...
    Mike
    Sods law mate... lol..at least you know the bulb sense circuit is working...
    Re. the occasional beeping, does it do this when its not raining.?
    I know a few of us have experience the odd beep in heavy rain, I've had it faintly beep a couple of times in very heavy rain, but touch would its been working fine for a few weeks now even in heavy rain.
    It stated in the fitting instructions to position the buzzer as far away as possible from the control unit, maybe it causes some interference to the unit... dont know, but to be on safe side I positioned the buzzer on the opposite side.
    Essex
    I only fitted it last Friday, i know the bulb was ok then, and was still showing up "bulb blown"
    so still needed to re-do the earth wire..
    It was a cisco make form eBay £13,99 jobbie.
    Other than the bulb problem, and blips (now solved) it works great.
    The buzzer/beeper is a wireless led unit, which is going to be tucked away somewhere out of site as its a bit tacky, and i cant think of anywhere suitable to put it....
    Ive yet to see what its like in the rain though..
    Mike
  1. Estate reverse light wire - ID for park sensors
    By isdmac in forum Electrical & ICE (including SatNav)
    Last Post: 11th July 2012, 20:01
  2. Help with reverse sensors
    By booker413 in forum Vectra C / Signum Car Chat
    Last Post: 6th April 2010, 22:41
  3. reverse sensors
    By solorider in forum Vectra C / Signum Car Chat
    Last Post: 12th October 2008, 21:15
  4. Reverse sensors
    By badge25 in forum Vectra C / Signum Car Chat
    Last Post: 17th November 2007, 23:10
  5. Reverse Sensors
    By armstma1 in forum Vectra C / Signum Car Chat
    Last Post: 6th June 2007, 20:57
