Results 1 to 10 of 15
Thread: NO Tach, NO Speedo, NO Temp, NO Nothing
    Regular Member ghostrider's Avatar
    On another planet
    Vehicle : 2.0l CDTi Bi-Turbo Insginia Sports Tourer
    Trim : Vx Line Nav Sri
    Engine : 2.0
    Question NO Tach, NO Speedo, NO Temp, NO Nothing
    Got in my car this morning and started it up, drove out the driveway, got out the car, closed the gate. Set off quite fast and looked down at the dash to see how fast i was going...... and i had lights on the dash, but all the instruments. i.e speedo, tach, temp, fuel where all at 0 and wouldn't move? So i stopped the car, turned off the ignition and started it again.... Everything started working again.???
    Any Ideas?
    What age is your car m8 as some early vecs had dash trouble if i remember rightly sure someone will be along soon to put me right though !!!!!
    Regular Member Doug-SRidirect's Avatar
    Hemel Hempstead
    Mine's done that three time is the last eight months. Gauges always start working upon restarting the engine. It's only the analogue instrument that stop working, the big screen computer still works, as do all the warning lights.
    I treat it like any other computer glitch - restarting the engine effectively re-boots the system.
    Doug
    Jan 2006
    Hertfordshire
    had same problem,also lost wipers, indicators,electric window switch,it was the c i m module at fault
    Drinky's right.. Dashes up to about 03 had probs IFIC..
    The instruments are now all electronic fed via the can-bus so a re-start should re-boot it.. take it to VX and get the software checked..
    On another planet
    Engine : 2.0
    Thumbs up
    Cheers Guys,
    It hasn't happened again yet, but if it does I'll take it in to VX and get it checked out.
    P.S 54 reg 2.0 DTi Estate
    Regular Member Ozz's Avatar
    Sydney, Australia
    Hmmmm, had this exact problem earlier on in the week. Leaving the parents in laws after dinner checked to see my speed & nothin'. All lights were working fine but no temp, tach, speedo or fuel gauge movement. Turned the car off, then on after 20secs & all was fine. My car is a late 04 so should have all the latest gear prior to facelift. Car will be going in for a scheduled service within the next month so will have the dealer check evrything. Will there be some sort of error log on the car computer for this ??
    Regular Member philzi's Avatar
    East Yorkshire
    Default Sounds like you have....
    ....the 'Nightscreen' button off the Saab 93.
    The 93 has a great button on the dash, it turns the lights and the dials off the dash all apart from the speedo.
    Wondering whether as the Vec C is effectively the same as the 93 (and the caddy bls) that this option is actually in the CANBUS system and just flagged in the software as turned off. But occasionally turns on in early cars....
    Regular Member david173's Avatar
    Dec 2005
    Dumbarton, Scotland
    I had this problem for the three years I had my Corsa, the old classic intermittent fault. needles would all just drop and die whilst driving. Then next startup the engine would start for a few secs then cut out. They replaced the dash, replaced instrument cluster, replaced the ECU, replaced a whole load of wiring, still was never 100% fixed. Vx admitted they didn't know what the hell was wrong with it, throw some useless Arnold Clark employees into the mix and lets just say it was SOLD never really sorted!
    Jan 2006
    Hertfordshire
    Default cim
    Ozz
    just seen your post,on mine it turned out to be the control information module,was doing the same as yours,but it became more frequent until,it tripped after 20 seconds every time,I also had no wipers or indicators,electric window switches,as i remember it cost about £576 to replace at Vauxhal main dealer
  1. speedo led
    By VECTRAMAN in forum Vectra C / Signum Car Chat
    Last Post: 12th December 2012, 20:03
  2. sri speedo. will it fit
    By luke.oldham in forum Electrical & ICE (including SatNav)
    Last Post: 7th April 2010, 09:42
  3. speedo
    By delboy2028 in forum Vectra C / Signum Car Chat
    Last Post: 25th February 2010, 23:58
  4. rev counter/speedo/temp gauge/fuel gauge stopped working
    By bloodworm in forum Electrical & ICE (including SatNav)
    Last Post: 19th July 2009, 00:28
  5. Speedo out by at least 5%, what can I do about it???
    By merikiito in forum Electrical & ICE (including SatNav)
    Last Post: 25th July 2008, 14:43
