Thread: Lamp Warning Light
    Blantyre
    Default Lamp Warning Light
    Right, all this started a few weeks ago when i got the lamp light with the exclamation mark through it, and was advised by guys on here, could be a few things, so got to work checking them out
    Today i lost the will to live and replaced nearly every bulb in the car
    DIDNT SOLVE THE PROBLEM
    SO..... got mrs spennny to sit in the car and press the brakes, and a strange thing is happening..... on the back cluster it goes from top to bottom
    1. Indicator
    2. Dont Know
    3. Brake / Side lights
    4. Fog Lights
    5. Reflector
    6. Reverse Lights
    She pressed the brake pedal and the rightside 3rd light down came on as you would expect, but on the left hand side, the second light down came on .
    SO i removed the second light down from the left hand cluster and both brake lights worked, but when re inserted, light No:2 came back on and the brake light (left) went out
    YOU WITH ME
    So, i still have the warning light on the dash. but all lights are working, few questions , how may back fog lights should come on, currently i have only one on the right hand side, (should there be 2) and also what is the second bulb from the top
    Sorry to go on, but its stumped me, I think its the left hand cluster / rails thats at fault.....any ideas
    All replied appreciated
    Oh and i have a full set of bulbs now
    what you need to do is clean the terminals on the bulb holder on the unit that isn't working...there will be surface corrosion that is causing a difference in resistances that upsets the lighting controller...
    the reason that it lights the other bulbs?..it's safety feature..to avoid having a duller brake light on one side... dead clever these vectra's.....
    You only have the offside fog as thats all that is wired up and all that is required. The other one is just a spare lamp holder. IN THE MANUAL it does say that if you blow a brake light it will use another lamp in the cluster as a safety feature so you still have all your lights working.
    Blantyre
    Cheers Guys, Will have a go tomorrow , anything special to clean the terminals ??
    Emery cloth, wet and dry, anything like that will do.
    Oct 2006
    Waterloo, Liverpool
    13 Post(s)
    Trim : DESIGN
    Engine : 1.5T (165)
    Year : 2018
    Mileage : 220
    Yes, and rather than have a pair of single old-fashioned twin filament 5W/21W bulbs on each side you have a pair of 21W bulbs which can also be 5W when lit as rear lights. Expected to find a twin filament bulb when I had a brake light failure message as I knew that the tail light and brake light were both coming from within the same part of the rear cluster. Little did I know.
  1. Turn Signal Lamp/Indicator Warning
    By Nimbus in forum Electrical & ICE (including SatNav)
    Last Post: 16th October 2012, 23:58
  2. Strange intermittent left fog lamp warning
    By rheumatoid in forum Electrical & ICE (including SatNav)
    Last Post: 19th May 2012, 12:02
  3. Intermittent battery and steering warning lamp
    By Rapier in forum Electrical & ICE (including SatNav)
    Last Post: 3rd October 2009, 18:15
  4. Steering Wheel symbol warning lamp
    By goshawk590 in forum Electrical & ICE (including SatNav)
    Last Post: 17th October 2007, 16:56
  5. Fault warning lamp
    By David2452 in forum Electrical & ICE (including SatNav)
    Last Post: 5th December 2006, 21:55
