Results 1 to 10 of 11
Thread: tailgate problem, 5 door `02 sxi
    haworth
    Default tailgate problem, 5 door `02 sxi
    hiya, well the problem is that the tailgate only opens by way of the key into the lock assembly, when the button on the doors is pressed there is only an audible sound from the dash area, and if the button is pressed on the key fob it only shows the light, any advice? thanks.
    I take it you have left the boot lock in the 'unlocked' position?.. it does sound like the servo motor on the boot lock has gone...
    what happens if you do not insert the key, but just click the remote button then try to open the boot when the tailights are illuminated just by pushing the boot lock button in?
    haworth
    nothing happens at all, only the indicators flash once.
    so when you push the boot button in the centre of the boot, it won't let you open the boot?..
    haworth
    yep, the button does not move at all, in or out, not had the car long and there is not a handbook with it so i`m at a bit of a loss on the actual method to open the boot. the button is flush with the lock housing.
    right, well you can download the handbook from vauxhall's website's..'my vauxhall' section for free...you just need to register...
    sounds like it could need a new boot lock servo...if you are opening it right..
    haworth
    cheers, i`m onto the web 2nite thanks a lot Gsi3.2
    anytime matey..
    haworth
    wow!!!!!!!!!! just downloaded the handbook. well impressed with your help and ease of the vauxhall web, many many thanks, looks like i`m in front of the computer all night, again thanks for such a quick response.
  1. Tailgate problem
    By cendoubleu in forum Electrical & ICE (including SatNav)
    Last Post: 29th January 2013, 22:43
  2. Estate tailgate problem.
    By Saxman in forum Vectra C / Signum Car Chat
    Last Post: 13th April 2010, 18:33
  3. Tailgate sidelight problem
    By steeley7 in forum Electrical & ICE (including SatNav)
    Last Post: 6th February 2010, 21:58
  4. tailgate problem
    By victorM in forum Bodywork & Interior
    Last Post: 10th August 2009, 22:07
