Thread: FS: Complete Park Pilot set
    Northants
    Engine : 1.9TDCI [150]
    Default FS: Complete Park Pilot set
    Bought this with the intention of installing it in my Signum, but it never happened. This is the complete Park Pilot set with all the bits required to install it. Even the drill bit is included (which took a bit of searching, as 29mm drill bits are not that common).
    This kit is complete for a Signum. For a Vectra you'll need a different fitting kit. If you take a look at this image, you'll need the equivalent of part number 93160919 for the Vectra. Not sure how much different it is, but there is a different part associated with it. I paid £14.46+VAT for the Signum variant, so I expect the Vectra one to be similar priced.
    I'm looking for £110 posted (or £100 collected from Aylesbury, Bucks).
    Regular Member kenp's Avatar
    Kr. Hyllinge, Denmark
    Engine : 2.2 Direct
    does a set like that need tech2? (and do you have the wiring present at the dash?)
    Northants
    Quote Originally Posted by kenp View Post
    Yes, you will need a tech2 once it's all installed. The guide that goes with the kit explains exactly what steps need to be taken in tech2.
    With regards to the wiring at the dash, I believe that it is already present in the normal wiring loom, but you probably do need to check behind the blank park pilot switch position to see if there is a plug present.
    Engine : 2.2 Direct
    i know that there nothing behind my black park pilot switch..
    Northants
    That may just mean that the switch can't be used. The switch is only there so you can switch the Park Pilot off, by default the sensors will be on.
    I can' guarantee it will work for you though, so please investigate it further if you like.
    Regular Member Signum Dek's Avatar
    South Yorkshire
    Hi, does the metal work behind the bumper need to be altered at all, for this to fit.
    Thanks Dek
    Northants
    Yes, the instructions say that you have to make some cut outs in the crashbar behind the bumper for the sensors to fit through. It's got a template for this stuff as well.
    Regular Member shawzie's Avatar
    Oct 2007
    bradford
    pm sent
    Northants
    This is now sold subject to payment on friday...
    Northants
    Nope, that should be
    SOLD!!!
  1. advice needed to complete retro fit of front park pilot
    By driver9524 in forum Electrical & ICE (including SatNav)
    Last Post: 27th October 2012, 10:00
  2. Park Pilot
    By Simon_Fuller in forum Electrical & ICE (including SatNav)
    Last Post: 27th September 2012, 11:17
  3. Park pilot alert but I don't have Park Pilot
    By krisby in forum Vectra C / Signum Troubleshooting
    Last Post: 21st November 2011, 10:58
  4. Park pilot
    By hairy31 in forum Electrical & ICE (including SatNav)
    Last Post: 25th April 2010, 16:58
  5. Park Pilot
    By spennny in forum Electrical & ICE (including SatNav)
    Last Post: 9th December 2009, 20:26
vectra c park pilot
