Thread: Automatic gearbox oil and cooler info required.
    Yorkshire
    Default Automatic gearbox oil and cooler info required.
    Right got a replacement gearbox but as its from a breakers they have drained most of the oil from it. So how much oil do I require to refill it?
    Also does anyone know were this oil can be obtained at sensible money?
    I'm going to bypass the factory gearbox and install a seperate radiator but I'm unsure on the sizing and although I'd like to stick as big as I can get on I'm concerened that I could end up over cooling the fluid. Does anyone have any idea what size I require and where to source it from?
    Regular Member poves's Avatar
    lancashire
    Glad you got one mate , I aint got a clue how much oil you need to refill , but do keep us updated how you get on , I've heard a few tales of "make sure you get the box from the excact same age car " as it wont like your ecu etc , so keep us updated mate , gonna be doin this myself next few weeks.
    As long as the can/half canbus bit is ok then i can't see a problem. Good luck mate
    lancashire
    That came from an autobox specialist , he said you gotta be careful , maybe he is just scaremongering cos he wants the work , but he did say if I fit the box , he will set it up tweak it etc - He's in huddersfield by the way .
  1. gearbox automatic info
    By matt180 in forum Engine & Drivetrain
    Last Post: 30th September 2011, 13:47
  2. Replacement for the auto gearbox cooler
    By Lao in forum Vectra C / Signum Car Chat
    Last Post: 27th June 2011, 15:12
  3. Automatic Box oil cooler
    By Big Bri in forum Engine & Drivetrain
    Last Post: 5th September 2009, 17:58
  4. Information required re automatic gearbox
    By m0cea in forum Engine & Drivetrain
    Last Post: 18th January 2009, 22:19
  5. Auto Gearbox oil cooler seals
    By Jamesdti in forum Engine & Drivetrain
    Last Post: 20th March 2008, 08:25
