Results 1 to 10 of 15
Thread: Cant removing f***ng radio
    Regular Member nickd_m's Avatar
    Ely, Cambs
    Default Cant removing f***ng radio
    Hi all,
    I have just bought a parot handsfree and am trying to remove my stereo to connect to the rear. I have removed the tiny grub screws and have bought a double din pin tool from halfords and am still having now joy.
    When I push the prongs into the holes it seems to go all the way in but does not unlatch the fascia. Am I doing something stupidly wrong or can this just be a bit tempermental?
    As an alternative I have read that I can remove the glove box to gain acess to the rear of the stereo? - is this right|
    Many thanks, Nick
    Regular Member Vid's Avatar
    May 2007
    In the inventing shed...
    You need to angle the forks when you pull them back, they can be a right pig to get out, just keep your cool and persevere!!
    Here, there and every where!
    Regular Member MattW's Avatar
    Sheffield
    As above, it took me a good 15 minutes of wriggling and adjusting the forks to finally get them to grip the inside of the stereo to remove it from the cage.
    Ely, Cambs
    Cheers guys,
    Jesus this forum is good, 30 seconds a 3 replies!
    I'll go give it anouther bash!
    Has anyone had an experience of fitting a parot MK6000, it looks fairly straight forward...
    May 2007
    I watched Plasma dismantle Fil4822's car to get one in at Trax, I have never seen so many wires hanging from a car!! LOL!
    If you have any trouble, Plasma is the guy to ask!!
    Ely, Cambs
    Hey,
    Thought i would tackle the radio again today, after 30 mins still no joy. I perservered with the forks for about 20mins then decided to see if I could get to the cables by removing glove box but thats tighter than a nuns.... behind there.
    I have never known a stereo to be such a pain to get out. I am pushing the forks in as far as they will go, there doesn't seem to be any clicks or sounds like they have pushed a spring back. I will try again with a coat hanger as this may be thinner but has anyone any other bright idea's???.. other than take to a vauxhall dealer (I feel like such a failure lol)
    May 2008
    Tyneside
    After you insert the removal prongs, gently pull them apart against spring tension then withdraw the stereo. This compresses the springs and engages the prongs on the unit to enable withdrawal.
    west yorkshire
    Hi when you get forks in pull them outwards right side towards drivers door an left towards passinger door, this should grip stereo then while still applying pressure pull it out , good luck.
    Regular Member vectragsi3.2's Avatar
    Feb 2007
    cheshire/staffordshire
    i had trouble with mine what i did was take the middle air vent out and you can push the back of the stereo and i had a mate to pull it with the prongs it come straight out with a little force it turned out someone else had it out before and had bent one of the prongs on the stereo and thats why it wouldnt come out with just the prongs hth
  1. resetting trip computer after removing standard radio
    By forde in forum Electrical & ICE (including SatNav)
    Last Post: 11th February 2013, 11:25
  2. removing double din radio from vectra c
    By Daniel Dixon in forum Electrical & ICE (including SatNav)
    Last Post: 19th January 2013, 23:07
  3. Removing Radio cd30 and clock display
    By AlanT1 in forum Electrical & ICE (including SatNav)
    Last Post: 28th July 2012, 01:01
  4. Removing the Radio / Stereo cage
    By Silly Car in forum Electrical & ICE (including SatNav)
    Last Post: 7th November 2010, 23:40
  5. How Chuffed Off Am I... Removing My Radio
    By ccsnet in forum Electrical & ICE (including SatNav)
    Last Post: 23rd March 2008, 20:26
