Results 1 to 3 of 3
Thread: Air Con leak
    Regular Member joules2.0t's Avatar
    surrey
    Trim : SRI
    Year : 53
    Default Air Con leak
    While sorting out another problem on the Vec, I noticed that there was some yellowish green fluid around a cylinder in on the drivers side front (just behind the bumper) Turns out that the condenser dryer is leaking
    Air con has been working OK - not that it has had much use recently!
    Bottom line is £75 replacement part, £90 to have it repressurised and tested+labour. This is not at VX garage BTW.
    Anyone else had theirs fail or leak?
    it could just be the seal, if the dryer isn't obviously corroded..they are special little o rings...
    usually it's the condensor coils that rot and leak...either way, those aren't bad prices Joules..
    surrey
    Trim : SRI
    Year : 53
    Thanks. Thats good to know.
  1. Oil leak 150 cdti oil leak help
    By sr_fly in forum Vectra C / Signum Car Chat
    Last Post: 14th July 2011, 20:46
  2. Oil Leak
    By Tam80 in forum Engine & Drivetrain
    Last Post: 17th January 2011, 13:41
  3. Oil leak
    By Rich2.2 in forum Vectra C / Signum Car Chat
    Last Post: 19th May 2010, 20:31
  4. Leak, front end creak, refurb, bent locking wheel key and another leak =(
    By nick-v2.2 in forum Vectra C / Signum Troubleshooting
    Last Post: 15th February 2010, 19:58
  5. 3.2 oil leak from?
    By megaderek in forum Engine & Drivetrain
    Last Post: 29th September 2009, 22:45
