Thread: Tyre wear problem on 3.0CDTi
    Plymouth
    Default Tyre wear problem on 3.0CDTi
    Hi folk
    I have problem with my Vectra estate 3.0CDTi wearing tyres out. On the front inside shoulder there appears to be a groove being "carved" out of the rubber. This has eventually caused a tyre failure (luckily at low speeds). Its happening to both LH and RH tyres and on two pairs off tyres scince I have had the car. I contacted Vauxhall who stated they are not aware of any problems with this model. The tyres were Avon ZV3's which I rated highly but as of today its back on Goodyear OEM stock rubber. I'll endeavour to post a photo of the damage. Its ****** irritating as I have to keep a close watch on the tryes for the last 5000miles or so. Still getting 19K miles of of them though.
    Aug 2006
    Is a very naughty boy
    Were the Avons 91w or Xl rated? I take it you have done the first steps and had the tracking set up etc?
    Also did you contact Cooper Avon about the tyres in case there was a fault with them?
    Cumbernauld, Scotland
    As above, Vectra C 3.0 V6 CDTI auto estate : must have XL tyres
    Equally, new tyres fitted to the front will probably only last about 15K miles
    Once swapping occurs, the rear tyres (now on the front) will last to about 25K miles
    Outside edges wearing suggests incorrect tracking, so when the rears are swapped to the front along with new rear tyres, perform a full four wheel tracking
    Finally, what tyre pressures are being used?
    Plymouth
    Hi folks - thanks for the answers.
    The Avons were the correct rating according to the tyre fitter. No I have not yet contacted Avon, thats the next bit after battling with Vauxhall for a free suspension alignment check.
    As for tyre pressures they are at 39psi but I have been adding a little 40-42 psi in the rears more as I tow a boat/trailer combo of 3/4 tonne.
    I really need to get some photos on the forum for you all to see. Will report later
    Technical directors office
    i know exactly what you have, as i've seen it before....
    that was cured with better branded XL rated tyres and a front camber alignment session...cheaper softer tyres, like the avon's, just can't cut it on the front of the 3.0 V6..
    the person in question now runs GSD3 goodyears with no inner wear..
    Aug 2006
    Quote Originally Posted by BishBoshBash View Post
    The bit in bold is the weak link there. I had tyre fitters try to fit 88w's to mine. You need to check them yourself, not trust others to get it right. Only person I trust is myself!
  1. That ol' inner tyre tread wear problem again!
    By ukcommando in forum Suspension, Wheels & Brakes
    Last Post: 13th November 2012, 22:22
  2. tyre wear
    By dreams3577 in forum Vectra C / Signum Car Chat
    Last Post: 3rd November 2010, 20:08
  3. Tyre wear
    By fishphone in forum Suspension, Wheels & Brakes
    Last Post: 27th May 2009, 19:09
  4. outside tyre wear
    By whatthevecisup in forum Suspension, Wheels & Brakes
    Last Post: 7th April 2008, 21:17
  5. Tyre Wear
    By KC in forum Vectra C / Signum Car Chat
    Last Post: 26th June 2007, 22:34
