Thread: Limp mode problem...
    Regular Member dankidd's Avatar
    May 2008
    Newcastle
    Default Limp mode problem...
    Recently replaced a turbo boost pipe and the airflow meter everything was working hunky dory until last night. Was going nicely along at 95 then slowed down to 70 then built up speed again, then when it hit 83mph it went into limp mode. Knocked engine off then on again, did the same thing then on the third attempt of knocking engine on and off it was fine. Same thing happened on way to work this morning.... Any ideas?
    Have you checked the hoses are on tight after you had them off?
    May 2008
    Newcastle
    Yep... All checked
    boost sensor....give it a clean...
    May 2008
    Newcastle
    Shall try that thanks
  1. Limp mode.... Help
    By jodiexii in forum Y & Z30DT Specific
    Last Post: 2nd July 2012, 09:45
  2. Limp mode
    By griffgrin in forum Vectra C / Signum Troubleshooting
    Last Post: 23rd December 2009, 17:19
  3. Limp mode or dead mode
    By JSYSH466Y in forum Engine & Drivetrain
    Last Post: 2nd July 2009, 09:46
  4. limp mode+sort of usual problem 2.0dti
    By bobssignum in forum Engine & Drivetrain
    Last Post: 8th August 2008, 19:04
