Thread: spanner light comming on but goes off its self
    Regular Member peadar's Avatar
    Aug 2007
    in the glens of Antrim N Ireland
    Vehicle : ELITE
    Trim : FULL LEATHER
    Engine : 1.9 CDTI 150 BHP
    Mileage : 87,000
    Default spanner light comming on but goes off its self
    as above its on a 2.2dti sri it seems to happen when you drive at a constant speed for a period when spanner light comes on it wont rev above 21/2 000 any advice or help please
    Oct 2006
    southampton
    15 Post(s)
    if the spanner light comes on then there is a fault even if it goes out again, needs to be diagnosed as it should have registered a fault in the ECU.....
    Regular Member glynn's Avatar
    stevenage, hertfordshire
    i have had mine come on only when i start it up and then it goes out after about 5 seconds? but not today
    West
    Quote Originally Posted by peadar View Post
    whilst the light is on the engine ecu is in safe mode so the motor will not rev high until the light is out, as said get the fault codes read first & take it from there.
    a good place to start looking is vac hose conectors & tubes for splits, also air flow meters can fail & boost pipes split.
    Quote Originally Posted by glynn View Post
    This usually means there is a fault on the pre heating system as the light goes out as soon as there is a bit of heat in the motor.
    check and clean the bosst sensor .. the number one DTi favourite
    Aug 2007
    Vehicle : ELITE
    Trim : FULL LEATHER
    Mileage : 87,000
    where would that be located on my 2.2
    remove front engine plastic cover..look at where the boost pipe enters the engine in front of you.. in the first alloy elbow . it's the very first sensor.. one torx bolt and one connector..sealed with a reusable o ring..remove bolt and connector, twist 90 Deg and pull out..
    the little bulb inside the plastic cage should be brass coloured, but i'd lay good money yours is black.. Carb cleaner will clean it up, but be gentle with it..
    Aug 2007
    Vehicle : ELITE
    Trim : FULL LEATHER
    Mileage : 87,000
    thanks Mark i will try this when i get home from work , thank everyone for your help . Mark is the 2.0 dti the same sensor i could try my wifes out of her zafira if it presists after cleaning ,i also have a rattle near the rear wheel when i close the doors and alot of creaking up front like suspension
    EVERYWHERE
    Can't say for the sensor,but "creaking up front" is usually a sign that a spring is about to give out!
    Aug 2007
    Vehicle : ELITE
    Trim : FULL LEATHER
    Mileage : 87,000
    i cleaned the sensor all was ok for a day or to , so cleaned it again and was checking oil level and noticed it was too far up the dipstick , as i have only bought the car i had got oil and fillters to service the car when i got time ,so this give me a push , i changed oil and fillters 1 week ago and touch wood no problems with sensor since thanks for your help .
    By Shadrack in forum Vectra C / Signum Troubleshooting
  2. Problems with Air bag light, ABS, Anti Skid & Spanner light
    By WeDesign in forum Vectra C / Signum Car Chat
    Last Post: 4th December 2012, 21:23
  3. Should I Have A Spanner Light aswell as an Engine Light on My Signum?
    By StreetDragster in forum Engine & Drivetrain
    Last Post: 18th August 2012, 11:57
  4. EGR Valve, Engine Management Light & Spanner Light
    By guygreen in forum Engine & Drivetrain
    Last Post: 12th December 2010, 20:09
  5. mot comming up ans abs light
    By twaiter in forum Suspension, Wheels & Brakes
    Last Post: 7th May 2010, 18:30
