Thread: 1.8 missfire.
    Scotland
    Arrow 1.8 missfire.
    Hello, my first post and i'm looking for help. Ive not made the move to vec c from b yet buy one of my mates has one.
    Its an 02 plate 1.8 and has had a problem with stuttering for a while(only happens at random times). The car developed a missfire a few weeks ago and he foned the..AA i think. The mech plugged in a fault reader and got 0170 and 1450..which from here is...
    http://www.iequus.com/support/obd2_definitions.php
    0170 - P0170, Generic, Fuel Trim (Bank 1).
    1450 - P1450, GM, BARO Sensor Circuit.
    Mate said the AA mech cleaned the egr and it ran smooth till he got on the motorway, then went back to running badly.
    Cars been serviced afaik. Just wondering what BARO sensor is. I thought problem might be dispack, but he got a fone call yesterday from a 'vaux expert' mech he went to(cars been with him for nearly 2 weeks) and they changed the pack but it was still missfiring...and they cant find whats wrong with it.
    Afaik there's no eml on atm but the problems still there.
    Found this...
    1.Was the car cold when you did this or was it already warmed up?
    2.Does the car missfire when revs increase while you are driving and engine is under load?
    3.When you first start the car from cold does it tick over ok or is it noisy/lumpy straight away?
    If the car was cold when you did this it is possible that you have burnt out an O2 sensor.
    If the car struggles to maintain power while driving, it could be the ecu cutting the HT spark to prevent engine damage, it will do this if it gets incorrect info from O2 sensors. Usually ok when first started from cold as ecu disregards O2 sensors initially to allow them to reach operating temp.
    PLEASE BE AWARE THAT CONTINUING TO DRIVE WITH FAULTY O2 SENSORS CAN WRECK THE CAT AND AIR MASS METER, CAT USUALLY BREAKS DOWN DUE TO RAW FUEL ON CERAMIC SURFACES, AIR MASS METER BURNS OUT/ OVERHEATS TRYING TO CORRECT INCORRECT O2 READINGS.
    from here...
    http://forum.vectra-c.com/showthread...light=missfire
    The 02 sensor bit seems to fit the symptoms...worth checking?
    Cheers.
    Sunny Dartmoor
    Got to be the next avenue to go down m8,if the Vx mechanic's don't know might be worth pointing them in the right direction,good luck.....
    Scotland
    Cheers for the reply...you dont happen to know if they do 02 sensors through the TC and how much they are? Cant see them in the book but im sure i got updates in a while back and they had added some things.
    they are avaliable TC....
  1. 2.8 Missfire
    By Ziggy in forum Engine & Drivetrain
    Last Post: 27th June 2012, 20:07
  2. Missfire!
    By R1-RAB in forum Engine & Drivetrain
    Last Post: 6th February 2010, 21:05
  3. missfire
    By alexgrfc in forum Engine & Drivetrain
    Last Post: 28th October 2009, 00:43
  4. missfire
    By robbie1944 in forum Engine & Drivetrain
    Last Post: 10th June 2009, 20:05
  5. missfire 2.2 dti sxi
    By woody in shetland in forum Vectra C / Signum Car Chat
    Last Post: 15th February 2009, 22:55
