Results 1 to 10 of 11
Thread: cdti not going
    ayrshire
    Default cdti not going
    hi looking for help my vectra has decided to stop running. goes with a tow but has no power. to start with when it was losing power if you accellerated hard it would cut out and after about ten mins of constantly turning it over it spring to life again. now it wont start off key. iv tryd fuel system which seems to be ok tryd cleanid injectors, no joy took cat oo still nothing and opened fuel filler incase pump breather pipes blocked still nothing tho. im thinking maybe electrical. has anyone had same problem or does vx know about this. please help. ps new to site so if did anything wrong posting this am pleading ignorance lol. but i do apologise if i have.
    Vehicle : Signum 2.0 DTi
    Trim : Elegance/Elite
    Engine : 2.0DTi
    Mileage : 73350
    Ok mate firstly what engine have you got IE petrol /diesel 2.0 ,1.9 etc
    Looking at his profile it looks like a 1.9 120 cdti.
    Do you have the engine management lights on?
    So if someone dives you a tow, it will run
    Equally, if the car does actually run and you apply power it switched off
    I certainly wouldn't be turning the engine over for as long as 10 minutes
    Perhaps a dozen times at the most
    How about a seized butterfly valve, that seems to be becoming the fault of the month now!
    ayrshire
    yes its 1.9 cdti i have the car with spanner lite coming on but just havnt reset it from doing the filter. wen it goes,if you give it sharp acceleration it just dies, wont go trying to bump in gear after it does this but wen you stop and giv it a tow it goes in half the length of itself. wen you have power its reaky wen thers no power its not. wots the butterfly valve? cheers guys for answering
    ayrshire
    been looking at other posts and saw few comments about , is it a dpf valve, wot is it?
    ayrshire
    aaaargh i wana burn my car
    Get the codes read. Makes it easier than guessing what could be wrong.
    ayrshire
    by that vi take it you mean plug her into diagnostics?
    Yes, the VX garage will charge about £30 to read the fault codes - or if your a member of the AA they can do it too, just tell them you have broken and they will come out. The codes will be fairly specific to the actual problem and if read correctly then will really help to sort your problem out.
  1. Weird noise from Signum CDTI 1.9 CDTI (150)
    By oneightycd in forum Diesel Engine related
    Last Post: 22nd June 2007, 22:27
  2. CDTi 120bhp Vs CDTi 150bp
    By bennyk in forum Diesel Engine related
    Last Post: 6th December 2006, 23:45
  3. CRD2 Tuning Box for V6 CDTi or 1.9 CDTi
    By The Doc in forum Parts for sale
    Last Post: 20th October 2006, 21:51
