Thread: Blanking off EGR Valve
    Sunny Dartmoor
    Default Blanking off EGR Valve
    Does this actually work and would it work on the 1.9cdti thats in the Saab??
    My brother recently had to have his replaced in is Saab and i told him about this blanking plate,could if be used for the Saab and would the wiring be the same????
    Cheers in advance.......
    Regular Member old cruiser's Avatar
    slough
    Only works on the 2.2's i.e Z22SE petrol engines mate as far as I know.
    Cheers Pete
    Regular Member rushy's Avatar
    Vehicle : 9-3 Wagon
    Trim : Turbo Edition
    Engine : TID (1.9 16v)
    Year : 2010
    Mileage : 137000
    Quote Originally Posted by glenboy View Post
    Yep mate work just fine on the 2.2 petrol (SE). But only on the 2.2 as the EGR works differently than any other lump. The ECU only monitors that the valve is working. Vocky makes the looms, in fact that will be one of his. He has a 1.9CDTI and said it wont work on that.
    Sunny Dartmoor
    Cheers rushy....
    Regular Member hibbsy18's Avatar
    May 2008
    Cambridgeshire
    i've blanked mine off its a 1.8 model an it seems to pick up earlier 2000rpm instead of 3000rpm
    slough
    Blanked mine off just before Xmas and had to fit the cheater as it's a 2.2 engine and has improved mine similarly.
    Cheers Pete
    Blantyre
    Quote Originally Posted by old cruiser View Post
    Cheers Pete
    I have a 2.2 direct, do i have a EGR valve........ if yes WHERE IS IT
    Vehicle : 9-3 Wagon
    Year : 2010
    Mileage : 137000
    Yes you do mate but yours is water cooled on the direct. Its situated on the end of the lump opposite to the chain end. You can get VX to tech 2 it out.
    Blantyre
    Do i have to clean it at any point ?? am a nOOb on these valves
    Vehicle : 9-3 Wagon
    Year : 2010
    Mileage : 137000
    You can but we dont. The fix for a dodgy EGR on the 2.2 petrol is to blank it off and Tech 2 it out as its not needed for UK MOT. The same engine in the US doesn't even have one fitted. The guys on the 2.2 forum blank them off to improve airflow into the intake manifold, TBH its very common over there just to deactivate it.
  1. Blanking EGR valve
    By mtqn in forum Engine & Drivetrain
    Last Post: 17th July 2012, 14:11
  2. blanking egr valve
    By Garfo in forum Engine & Drivetrain
    Last Post: 12th May 2011, 14:43
  3. Blanking Egr Valve
    By Simo87 in forum Diesel Engine related
    Last Post: 31st May 2010, 17:22
  4. Blanking EGR Valve
    By Nav-Man in forum Vectra C / Signum Car Chat
    Last Post: 25th May 2010, 19:31
  5. 120 8v EGR Valve blanking....
    By smiley-sri in forum Diesel Engine related
    Last Post: 14th August 2009, 23:08
vectra 2.2 direct egr valve cheater wiring
