Results 1 to 10 of 21
Thread: Milltek Exhaust Idea...
    Jul 2006
    Lightbulb Milltek Exhaust Idea...
    Browsing some of the tuners' websites tonight, I happened across Thorney Motorsport. They (and presumably others) sell a Milltek exhaust system for the VXR. It's hideously overpriced (£885 + ) probably because a) it's an approved VXR part and b) it's made by Milltek.
    But what got me thinking was the blurb that accompanied it...
    Quote Originally Posted by Thorney Motorsport
    The VXR Vectra is unique in the VXR range in that the exhausts main catalytic converters (cats) are housed in the systems downpipes. To remove these means major engine work so we have to retain them, however the good news is that their retention means can still remove the main cats underneath the car and replace them with straight through sections so power gains are actually pretty impressive.
    So here's what I was thinking. My engine is virtually identical to the VXR, the only real difference being the detuned software. I reckon I could get someone like MIJ to make me an identical exhaust system for about half of that cost.
    Whaddaya think?
    you could.....
    i'm about to start experimenting with Decatting the Gsi.... in fact i was having this very discussion with Big Phil last weekend ( you weren't hiding in my workshops were you?.. )..
    for the 3.2 it's very possible..worst case is you'd need a sports cat instead as the OBDII platform measures across either side of the top 'pre cats' and the main underfloor cat has no bearing on how the car runs...
    lasercut flanges are ordered.....pipes here...i'll let you know soon..
    Jan 2006
    Skynet HQ EMEC#5
    More experiments Mark, very good
    Regular Member ssmotoboyz's Avatar
    wednesbury
    Default mij exhaust/ thorney exhaust
    mines a3.0 cdti mij charged me 350 for afull system post cat removed ,impressed with the quality
    Regular Member LOCKSTOCK's Avatar
    SUFFOLK
    Just found this thread, will keep my eye on it as im very interest in sorting the exhaust on my car but choice is so limited on the 2.8
    The world famous city ground
    Vehicle : Vectra cdti estate
    Trim : Get a
    Engine : Dirty diesel
    can't see why MIJ or A N OTHER place couldn't do an exhaust, vxr or not....that price is unreal...
    are you doing the MR 3.2 recomendation too mark ????
    Midlands Mod Shop - NFFC.
    nope, i've looked into and spoke widely to folks about removing the precats..it is possible, but you have to reprogram the engines ECU to remove the last two lambda sensors and make it make fuelling adjustment corrections off the first set only..the guy who had this done ( Sparky VXR ) weighed out several thousand on it, for only mild gains..
    So, for now, i'm just dumping the centre cat as it's the biggest restriction and the removal of it is 'blind' to the engines ECU...If the cars weren't OBDII and only had 2 lambda sensors it would be a doddle to do...whack on some BTB manifolds, and rip out the main cat...but no..that would be too easy....
    Regular Member VinnyPeewee's Avatar
    Mar 2007
    N.Wales
    I have de-catted mine.... and have a Remus cat-back system (only a center de-cat) ... as you said Mark.. the ECU doesnt notice its gone as its not monitored at all by Sensors. Massive improvement on throttle response.... (mines a auto so makes a difference!) makes a lovely sound too.. a nice 'roar' when the throttle's opened... not too loud at all.
    The Pre-cat.. or Mani cats (manifold cats) would be a massive nightmare to remove.. and would cause massive emmition problems come MOT time!!!.
    However my Vectra still Passes emmittion tests with the center Cat removed.. and it also bumped my MPG up by 1or 2 after removing it!!
    Only cost me £30 for an exhaust center to make a stainless de-cat piece up and fit it... Well worth it!!!
    VIP-Member GSiFan's Avatar
    Houghton Regis, Bedfordshire
    19 Post(s)
    Vehicle : Vectra GSi 3.2 V6
    Trim : GSi
    Engine : Z32SE
    Mileage : 216,400
    I can feel my first GSi mods coming on...
    Paul
    2003 Vauxhall Vectra GSi 3.2 V6
    Vinny.. music to my ears...
    when the flanges turn up, i'll have to knock a few decat pipes out..
  1. Exhaust, any idea on price?
    By GoldenWonder in forum Vectra C / Signum Car Chat
    Last Post: 26th August 2012, 19:25
  2. signum cdti exhaust idea
    By rob1981 in forum Vectra C / Signum Car Chat
    Last Post: 12th April 2012, 09:48
  3. VXR Estate milltek exhaust
    By tangoman in forum Vectra C / Signum Car Chat
    Last Post: 8th August 2009, 20:50
