Results 1 to 10 of 16
Thread: headlight adjustment
    Regular Member Robbie69's Avatar
    Default headlight adjustment
    When I turn the nob inside to adjust the headlight angle nothing happens? I mean the switch next to the headlight nob. Anybody got any ideas, I hope this makes sense?
    Thanks in advance,
    Robbie
    Jul 2006
    <silly schoolboy giggle>
    You said nob
    </giggle>
    Anyway... Do neither of the headlights move? If neither move, it's probably a duff switch or connection. If only one moves, it'll be a faulty motor.
    Regular Member sig63's Avatar
    Belgium
    Vehicle : Opel Insignia
    Trim : Cosmo
    Engine : 2.0 CDTI
    Year : 2011
    maybe a stupid question, but did you try it while the engine was running?
    neither move, engine on or off when I twist the NOB! Confused!!!
    Jul 2006
    Mexico
    A faulty knob or electrical connection...or both motors are fried which is not likely
    May 2008
    Tyneside
    Had this problem on mine. Turned out both the headlight units had become detached from the adjustment motor. If you remove the rubber cover behind the headlight check if the internal unit moves. The motor can disconnect from the internal unit if too much pressure is used when changing bulbs. It is a ball and socket connection and is a bit fiddly to reconnect.
    Quote Originally Posted by tridley View Post
    Thanks for that mate, I will take a look tonight when I get home. I'm sure it used to work and I have been changing bulbs around. Got rid of my cheap and nasty HID kit and fitted some PHILIPS X-TREME POWER, they are great!
    Thanks again
    May 2008
    Tyneside
    Just a thought, have you checked the fuse. Sometimes the solution is a simple one.
    Is there one? I'm so simple myself I wouldn't even know. I will also have a look at this, thanks.
    Sunny Dartmoor
    Quote Originally Posted by Robbie69 View Post
    have you got a link for those please Robbie??
  1. Headlight Adjustment
    By Siggy08 in forum Electrical & ICE (including SatNav)
    Last Post: 11th August 2012, 19:05
  2. Headlight Adjustment
    By Aidi in forum Vectra C / Signum Car Chat
    Last Post: 26th September 2010, 22:27
  3. headlight adjustment-HELP
    By nikroc in forum Bodywork & Interior
    Last Post: 27th November 2009, 11:54
  4. Headlight adjustment..'how to'
    Last Post: 27th November 2009, 00:11
  5. Headlight adjustment
    By Bops in forum Electrical & ICE (including SatNav)
    Last Post: 3rd September 2009, 21:39
vectra c headlight adjustment motor
vectra c headlight motor fuse www.vectra-c.com
vectra front headlight motor adjustment
