Results 1 to 10 of 11
Thread: Lowering Question
    Regular Member Genterz's Avatar
    Herts
    Default Lowering Question
    Here's a question:
    If I have an LS Vectra and lower it on lowering springs by -35mm, it will sit at height "A".
    If an Sri was lowered by -35mm, would it sit exactly the same as the LS after that had been lowered or would my LS still sit higher?
    The reason I ask is because the Sri already sits -20mm lower than an LS.
    Got your head round that!?!?
    Sunny Dartmoor
    They'd be lowered the same amount.......
    Regular Member vectragsi3.2's Avatar
    Feb 2007
    cheshire/staffordshire
    what glen said it is only different to start with because the sri spring is shorter
    Jul 2006
    Yep. They'd end up the same height.
    Herts
    But then if I owned an SRI and bought -35mm springs, I'd expect it to sit 35mm lower than what it did already.
    If my LS sits 20mm higher than an SRI, surely I'd need to lower it 55mm to be at the same height as the lowered SRI???
    Jul 2006
    No. Any figures quoted are lower than standard height. The SRi is -20mm lower than standard. Eibach springs will lower -30mm over standard, regardless what height you start at.
    Herts
    Oh I see! Cheers Paul, that answers it.
    So to sum up then, if I've got an SRI and think by fitting -35mm springs the distance between top of tyre and arch will reduce by 35mm, then I'd be wrong.
    If howerever I have an LS and fit the same springs, the distance will reduce by 35mm.
    Sorted.
    West
    Yes that's correct & I'm sat here waiting for my eibachs to arrive impatiently...
    Mot time this week, & it will not pass with the broken standard front spring.
    hence the lowering...
    Regular Member dave16v's Avatar
    Jun 2007
    Scotland
    Vehicle : Ampera, Astra Sri
    Trim : Sri
    Engine : 1.4 hybrid, 2.0 cdti
    its a long wait mate , i waited nearly 3 weeks for mine ,,every day expecting a deliv, but it will be worth it when they arrive
    To pick up on that point, what springs would be recommended to lowerr and SRi Estate by approx 30-40 mm?
    I wouldn't want to spend my hard earned and find my car has dropped just 10mm
  1. Lowering Question?
    By Del101 in forum Suspension, Wheels & Brakes
    Last Post: 27th January 2013, 18:28
  2. camber question after lowering
    By Mads in forum Suspension, Wheels & Brakes
    Last Post: 28th May 2011, 13:24
  3. lowering question
    By davidmcd2002 in forum Vectra C / Signum Car Chat
    Last Post: 30th March 2011, 15:32
  4. lowering question
    By MSharkey in forum Styling
    Last Post: 15th October 2009, 11:22
  5. Another lowering question !
    By FIL 4822 in forum Vectra C / Signum Car Chat
    Last Post: 28th March 2008, 12:34
