Results 1 to 2 of 2
Thread: drive belts again!!!!
    edinburgh
    Default drive belts again!!!!
    Hello all! much help needed again pls. My car is becoming the death of me! Vaxhole repaired my drive belt tensioner 2 years ago under warranty. On driving home from a holiday the battery light came on again in the driveway, looks like either a belt has snapped or another pully has come off again. Dealer not interested in repairing it so is it easy to do for the faint hearted or is it an expensive garage job? Thanks guys
    the first thing you need to do is open the bonnet and see if the belt is still on all the pulleys, and if the bottom engine pulley is in one piece...if it's broken into two rings then the part is £220+V but it will need someone with a big airgun to undo the bottom bolt.. not really an 'at home' DIY procspect but any independant could do it..
    If the belt is on, then it could be either a failed alternator or battery.. a simple check with a multimeter will tell...the battery should be at 12V static, no less than 10.5 V when satrting and between 13.4v and 14.4V when the engine is running...
  1. Ancillary drive belts?!
    By Chip in forum Vectra C / Signum Car Chat
    Last Post: 1st December 2012, 14:24
  2. Cam belts
    By SRIRob in forum Vectra C / Signum Car Chat
    Last Post: 4th January 2010, 23:01
  3. Belts
    By bgm46 in forum General Chat
    Last Post: 29th January 2009, 09:56
  4. ****** drive belts
    By geebee007 in forum Engine & Drivetrain
    Last Post: 18th September 2008, 21:11
  5. Noise from drive belts
    By chrismiller in forum Engine & Drivetrain
    Last Post: 15th October 2005, 20:31
