Thread: Brake hoses ?
    Forum Moderator FIL 4822's Avatar
    On a French Carp lake somewhere x
    6 Post(s)
    Vehicle : Insignia VX-line RED Tourer
    Trim : No, over weight!
    Engine : Flux Core Capacitor
    Year : 1 A.D
    Mileage : Rising
    Question Brake hoses ?
    Is there a stainless braided brake hose set for the Vec-C ?
    I've heard somewhere there is one but may be problems with it fitting correctly ( banjos are different) ?
    Anyone know of these kits and where i could get one/how much ?
    Thanks in advance.
    LMF sell the goodridge kit, but ask them to check it fits the vectra -c rear banjo's as they didn't used to...
    fronts fit fine, rears were undersize to the bolt.....
    Steve was knocking them out for around £50
    Regular Member Thunder's Avatar
    Apr 2008
    North Yorkshire
    Vehicle : Vectra C Facelift
    Engine : CDTi 150
    Mileage : 71000
    looks like you can get them here
    Vauxhall Vectra 'C' (All Models) (KCB-333-832-4) 2002 - 2006
    Zink plated £61.24
    Stainless Steel £75.36
    both including postage
    http://www.goodridge.co.uk/buy-goodr...ses.php?mk=333
    Tyneside
    I got a set off Ebay, thr fronts are fitted, but I haven't tried the rear ones to check and see. They came directly from Goodridge so I'm still hopeful.
    I got SS and paid less than the above price for the Zinc plated ones.
    Regular Member phil67's Avatar
    Nottinghamshire
    Vehicle : Vauxhall
    Trim : Exclusive
    Engine : 1.8
    When i was trying to get a set of the goodridge hoses, LMF advised that they didnt sell them for the veccy due to the rears not fitting, so i rang goodridge direct and spoke to one of their chaps in the technical team (helpful) and he advised me that there is two sizes that vauxhall are using either a 10 or a 12 and advised me to measure the bolt after dismantling the brake and then having to rebleed it, and then order a set which would be with me in approx two weeks of ordering.
    I hope that this helps
    Feb 2007
    Glasgow
    I got a set, the fronts fitted no bother, but the rears were 10mm unions which didn't fit.
    Got in touch with Goodridge and they sorted it out Can't fault them for customer service
    Like phil67 says, best to check before you order them.
    6 Post(s)
    Year : 1 A.D
    Mileage : Rising
    So it seems that the best thing to do is order the hoses anyway and send the rears back to Goodridge for the correct size banjo's ?
    Thanks for the replies guys.
    Sunny Dartmoor
    6 Post(s)
    Year : 1 A.D
    Mileage : Rising
    Quote Originally Posted by glenboy View Post
    Mines on an '07' plate but '06' build presumably. I take it i'd be ok with these then ?
    Sunny Dartmoor
    I would say so....
  1. For Sale: HEL braided brake hoses
    By Big Red in forum Parts for sale
    Last Post: 16th April 2012, 20:08
  2. removing brake hoses
    By mparks8590 in forum Suspension, Wheels & Brakes
    Last Post: 15th February 2011, 10:09
  3. Goodridge Brake Hoses
    By dae36 in forum Handling & Braking
    Last Post: 29th October 2009, 02:12
  4. Brake Hoses
    By lizard in forum Handling & Braking
    Last Post: 8th August 2009, 21:14
  5. Brake hoses cut on VXR Calipers
    By WooSAABy in forum Vectra C / Signum Car Chat
    Last Post: 7th January 2009, 00:09
