Hi Guys
I have found somtimes when i start my car it will die again a second later once it has been started any ideas?
Hi Guys
Possibly a faulty or dirty IAC valve?
Probably wrong but I didn't think the Direct had an IAC valve.
it doesn't... it uses the stepper motor on the intake flap to hold the rpm higher...
take off the air inlet hose at the intake manifold and see if it's got a dirty butterfly.. if it has , clean it with carb cleaner and see if that helps...
other causes could be wrong mixture, faulty plug etc etc...
does it flag a fault light?...
There is no carb, but the carb cleaner will clean the butterfly valve.
what Sean said..
My Vectra used to do this until it had it's last service.
Would fire up, and sound like it was running a tad rough, then the revs would suddenly drop off and engine would cut out.
Would fire up again and be fine, only did this around 2 times in a year.
Took it into Independants for a service, and made sure that plugs etc. were replaced, along with oil + filter + fuel and air filter. Also oil they replaced it with was 5w 30, magnatec. Bin fine since
