Thread: air box mod 3.2
    Regular Member vectragsi3.2's Avatar
    Feb 2007
    cheshire/staffordshire
    Default air box mod 3.2
    hi all ive decided to take the induction kit off and go back to the air box with the k&n panel filter along with the air box mod. the question i have are there any pictures or does anyone know how the airbox fits back onto the car??? tia
    Jul 2006
    Northampton
    Trim : Sri
    Engine : 1.9 cdti 150
    there are some clips on the underneath. in th engibe you should see some mounting points, it slide on to thm. you may have to twist it slightly into position
    Feb 2007
    so there are no screws to screw in the base mate just on the lid to get at the filter?
    Sunny Dartmoor
    Yep
    Feb 2007
    cheers glen is that yep there is or yep there are just screws in the top?
    Jul 2006
    Northampton
    Trim : Sri
    just in the top
    Feb 2007
    got it in does the air flow meter go directly in to the box or is there a piece of pipe in between?
    the MAFgoes into the lid of the box.. the pipe goes after the MAF and onto the intake..
    Hungary
    I have my 3.2 Siggy with the longer intake pipe (with the two "blind tunnel").
    Did you experience any difference with the shorter intake pipe (p/n 9177099) with the trumpet removed under the filter?
    Hungary
    Finally I 'installed' the shorter intake pipe.
    Results:
    a, this engine has a veeeery good sound, just it was hiding it before
    b, there is a small whistling starting from 5k rpm, not that much like a turbo, but nice
    c, the sound makes me revving the engine more (serious addiction)
    I do not think it resulted any noticable other change in the idle or in the performance.
