Results 1 to 10 of 14
Thread: Trembling on idle, SRI CDTI 150
    Birmingham
    Default Trembling on idle, SRI CDTI 150
    Hey guys.
    My dad has a facelift SRI CDTI 150 and over the last week or so, have noticed that when its idling it sort of trembles.
    Very had to explain but it just sort of feels as though its cold. Best word is a tremble.
    Doesnt feel as though its going to turn off, nor do the rev's fluctuate.
    Any ideas or another trip to the stealers?
    Thanks.
    Bye bye Vec B
    - Hello Siggy!
    Regular Member Sean-2.2Direct's Avatar
    Apr 2008
    Liverpool
    Quote Originally Posted by Vaux-Man-G View Post
    Hey guys.
    Thanks.
    Hi Mate i experianced that sort of problem in my girlfriends 2 ltr 206 CC
    not to sure what and that was and that was a petrol would it have anything to do with the idle control valve?
    Regular Member Auto-Brite's Avatar
    Staffordshire
    Hi Mate
    I had this on my Vec 1.9 CDTI SRI when i had here (sob!!)
    It sort of trembled when i started here up in the morning or from cold, as soon as she went down the road for a bit she was fine-up to minutes or so..I do know what you mean.
    Birmingham
    Quote Originally Posted by Auto-Brite View Post
    Hi Mate
    Exactly that. It doesnt cut out nor does it stall, just trembles!
    Did you ever get it sorted?
    It doesnt bother me, just like to have things put right!
    Bye bye Vec B
    - Hello Siggy!
    Staffordshire
    No mate i did not really bother,it only did it from cold and a mile down the road and she was fine.I just thought it was normal for a car to do that when it was cold or just started up? Even when i had her serviced it was still the same.It was ever so slight tremble as if the car shakes for a short while.
    Birmingham
    May do the same....like I say, it doesnt bother but dont like it!
    Bye bye Vec B
    - Hello Siggy!
    May 2006
    scotland
    Yep my cdti (150) is exactly the same. I liken it to the feeling of a badly setup carb with choke pulled on (for those of us old enough to remember ill twin SU's). It never caused me concern on th cdti..
    our 150 used to do it... the cure.. even after VX feild techs looked at it?....
    I sold it.....
    they changed maps, injectors, turbo's etc etc all manner of sensor's... but it still did it..
    Birmingham
    Should I just leave it then as the car will be out of warranty soon and knowing my luck, it will screw up straight after leaving me with a shocking bill to foot!!??
    Bye bye Vec B
    - Hello Siggy!
    take it in and report it.... leave it with them overnight for them to do a coldstart and they can see it failing to run smoothly...
    then , when it's out of warranty, as you have already reported the fault they will have to cover it..
  1. V6 CDTI Idle rate
    By ABO in forum Engine & Drivetrain
    Last Post: 14th August 2011, 21:47
  2. Few engine trembling when first start
    By Lao in forum Engine & Drivetrain
    Last Post: 18th March 2010, 18:10
  3. engine idle on the 150 cdti
    By rozzer2006 in forum Engine & Drivetrain
    Last Post: 11th January 2010, 20:21
  4. Replies: 4
    Last Post: 31st July 2008, 15:29
  5. CDTI 150 rough idle
    By POAH in forum Engine & Drivetrain
    Last Post: 13th November 2007, 17:19
