Thread: GSi Brake upgrade to 314mm?
    Regular Member fuzzbomUK's Avatar
    Milton Keynes
    Default GSi Brake upgrade to 314mm?
    Hi all,
    I have a 52 plate 3.2gsi, being a more early 52 plate its has the 302mm disc's on it.
    Now a few questions..
    1) Will the calipers on there take the 314mm discs and pads?
    2) if they wont fit on the old calipers, would it be worth the upgrade for the extra 12mm?
    thanks
    Full Member Big Sig's Avatar
    Yes its worth the upgrade. Are you sure you have the 302's? not many did but it is possible. I think Drinky did his on his 3.2 Elite.
    Oct 2006
    Waterloo, Liverpool
    12 Post(s)
    Trim : SRI NAV XP
    Engine : 1.9 CDTI 150
    Mileage : 72K
    I changed to 314's from 302's on my 2.0T. The calipers are considerably larger and the bigger brakes do make a world of difference. Clearly the V6's should all have had 314's from the outset.
    Regular Member yorkshireborn's Avatar
    Apr 2006
    Rotherham SouthYorkshire
    Vehicle : saab 95
    Engine : 2.3t
    the 52 , 03 , 53 plated GSi's were fitted with 302mm front discs.
    late 53 and onwards were fitted with 314mm.
    1: i'm afraid the calipers are completely different between the 302 and 314's.. so it won't fit..
    2:.. you sure will notice a difference... the 302 cars are underbraked anyway.. hence why VX went 'up' in size...Duncan had 314's fitted to his 302 equipped 2.0T and he certainly noticed....
    I've gone one step further and now run 345mm on the front of mine..
    Milton Keynes
    Thanks for the quick replies.
    I will now have to go on the hunt for a set.
    While i was there i was also thinking about doing the goodridge braded hose upgrade, did that on an old orion years ago and it made so much difference.
    just make sure it's a veccy c kit, as some folks have been sold kits with the rear fitting made too small to be used..
  1. For Sale: 314mm brake upgrade
    By Craig1985 in forum Parts for sale
    Last Post: 3rd May 2012, 15:11
  2. 314mm brake upgrade
    By peteopc in forum Suspension, Wheels & Brakes
    Last Post: 23rd August 2009, 11:43
  3. 314mm upgrade brake kit??
    By Jay Kay 313 in forum Suspension, Wheels & Brakes
    Last Post: 6th September 2008, 12:13
  4. 314mm brake upgrade
    By steve1975l in forum Suspension, Wheels & Brakes
    Last Post: 30th June 2008, 21:12
  5. 314mm brake upgrade
    By PeteRs in forum Vectra C / Signum Car Chat
    Last Post: 17th June 2008, 14:23
vauxhall vectra c gsi 3.2 brake upgrade
