Results 1 to 10 of 15
Thread: How to deal with dealership?
    Regular Member luckyluke's Avatar
    May 2008
    S'port and L'pool
    Default How to deal with dealership?
    I've got two problems with my car - slightly juddering when setting off and driving with low speeds and unevenly worn rear disc/pads. Both cases well known to Vauxhall but dealership where I service my car doesn't see the problem. I'd contacted Vauxhall and they told me I have to take it again to the dealer. i know what delar is going to say - there're no problems. So there'll be a nice ping-pong with me being a ball. I was thinking printing some thread should do some work but as it was simple with CDC40 Opera losing stations (there was VX case number) there aren't case numbers for my problems (that I'm aware of). Can you suggest what sort of politic I should play with my dealer to have thse issues sorted out?
    thanks
    simple.. print off and take with you the threads on clutch judder and folks having theirs replaced by VX, and the same for the rear brakes... take them in with you.. that way they can't claim that no-one has ever had these faults....
    mind you, the uneven wear on the rear brakes sounds like sticky calipers , so you won't get them replaced under warranty/FOC as brakes are a wear and tear part..
    May 2008
    S'port and L'pool
    I can't find it now, but I'd find in the past pictures of disc/pads wear like mine and it they're replaced under warranty... I need to find this thread.
    I've had rear brake pads and discs replaced under warranty, even taking into account wear and tear
    What you need to show is excessive wear and tear, which is abnormal, and possibly caused by component failure
    When booking your car in, just simply list the fault or symptom, don't go into any detail
    Once the work is completed, do NOT pay for it immediately
    Ask for the key to the car so that you can take a short test drive to check if the fault or symptom has been rectified (if the dealership say no you have to pay first, then avoid them in the future)
    If you are happy then pay and leave
    However, monitor the fault or symptom over the next month or 1000 miles
    If there is even a hint it has reoccured, either book the car in or take it back for a reinspection
    After the second repair, repeat the above process
    If the problem is still present, ask the Service Manager to take a short drive with you, so that you can demonstrate the issue
    If after another visit the problem remains unresolved, contact VX and advise them you are taking the car to a different dealership for an independent inspection
    When this happens they will usually ask you to contact them with those details and they will send an area Technician to oversee that inspection, and then report back to the original dealership which missed the fault
    May 2008
    S'port and L'pool
    Thanks for advices - I'll see the dealer tomorrow... hopefully all can be sorted out. I'll take some pictures of brakes to discus on forum if they'te OK.
    thanks again - not too much response but highly valueable
    btw - to m8internet - have you got any pictures of how were your brakes worn?
    May 2008
    S'port and L'pool
    Quote Originally Posted by luckyluke View Post
    I've found this thread - here - my discs look exactly the same
    Regular Member yorkshireborn's Avatar
    Apr 2006
    Rotherham SouthYorkshire
    Vehicle : saab 95
    Engine : 2.3t
    nothing wrong with those discs thats just normal wear mine look the same
    its only £80 for new disc & pads set will cost u over £200 seperatly.
    May 2008
    S'port and L'pool
    Quote Originally Posted by yorkshireborn View Post
    In my opinion it's not normal compared to front disc. I checked all cars on our car park and rear disc had similar usage (no such furrows) to front ones. Also remember condition of my previous car and it wasn't like this. Though I had a look on VX dealer parking and all cars had such a 'rubbish' rear discs.
    May 2008
    S'port and L'pool
    Spoke with technician. Rear brakes they will clean pads and everything, this should help. There is no excesive wear. However I did yesterday some emergency braking on the beach and you can see pads and discs now work better.
    Gears change - they will check linkeage and bleed brakes - see if it helps.
    He said he can feel this judder, however it's not bad. I recon I'll leave it as it is and wait till judder be stronger. He admited VX exchange clutch and flywheel but wasn't sur if it's for my engine.
    In total - I'm happy. My concerns were confirmed and should be sorted. However one question: if this judder thing is not very bad would you go for clucth/flywheel change or wait longer? I'm sort of affraid after changing them, the ca may not be the same
    Northampton
    Engine : A20DTH
    Mileage : 88000
    I would not put up with any judder. If it is under warranty get it done
  1. ha ha - dealership repair prices
    By kabooboo in forum General Chat
    Last Post: 10th June 2010, 15:56
  2. VX dealership excuse of the year?
    By m8internet in forum General Chat
    Last Post: 24th January 2009, 09:12
  3. A few hours in the dealership
    Last Post: 23rd December 2008, 22:42
  4. Good dealership, none car
    By Guyver1 in forum General Chat
    Last Post: 3rd October 2008, 10:30
  5. dealership trying to con me?
    By lewisboss777 in forum Vectra C / Signum Car Chat
    Last Post: 28th February 2008, 20:19
