Thread: Starter Motor
    Jul 2006
    Newport, South Wales
    Default Starter Motor
    Been having trouble starting lately - the dreaded clicking problem. Measured 12.25V across battery when engine off, 14.25 when running. Green LED is lit on the battery.
    Can someone please tell me where the starter motor is on a 1.8 petrol engine - can't see it from the top of the car. If you could post a picture to show me I'd appreciate it. I can then check the connections to the motor as my next step.
    thanks
    Regular Member Ste's Avatar
    ..... Driving the Jaguar XF
    Vehicle : Jaguar XF 3.0D V6
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    Is the battery, earth and SM cable connections secure and not corroded? Maybe worth a removal of each cable and a clean and refit. Obviously you will need the stereo code if you remove any battery cables.
    Jul 2006
    I've taken the battery terminals off, cleaned and copper-greased them before refitting. I want to clean the SM terminals, just need to know where the thing is !!
    it's down the back of the engine, underneath the inlet manifold...
    what you could have is a dead cell in the battery.. have you done a 'drop test' to see what the battery pulls down to when starting?.. if it gets under 11V then it shows a dead cell and reduced starting performance..
    other than that, it's as STE said.. remove and clean all high current connections including the engine earth to body and the body eart to battery connections..
    Jul 2006
    thanks - I'll take a look later. Will I be able to get to it from the top or do I have to lift the car?
    from underneath is easier...the inlet hides too much..
  1. Starter Motor
    By dezzyb66 in forum Engine & Drivetrain
    Last Post: 25th August 2012, 13:10
  2. Starter Motor?
    By leedslads in forum Vectra C / Signum Car Chat
    Last Post: 6th February 2012, 15:18
  3. Starter motor help.
    By 123rado in forum Engine & Drivetrain
    Last Post: 6th January 2012, 21:30
  4. Starter motor
    By pjabrid in forum Vectra C / Signum Car Chat
    Last Post: 20th February 2011, 22:40
