Thread: Noisy Starter Motor......
    Merseyside
    Default Noisy Starter Motor......
    On a full cold start up - ie. when its been left standing overnight there is a rather unpleasant low pitched squeel from the starter after the engine has fired and I've released the key.
    Any ideas what it may be?? It only happens when the car is stone cold and any other time of day it starts quietly.
    It is a 1.9 150 CDTi on an 06 Plate with 42k on the clock.
    Help appreciated!
    Regular Member Ste's Avatar
    ..... Driving the Jaguar XF
    Vehicle : Jaguar XF 3.0D V6
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    As it's covered under warranty, get them to have a look. To me it sounds like the drive mechanism of the SM isn't disengaging quietly, could be an early sign of something that will only get worse.
    Merseyside
    Cheers fpr that - will ring them asap to get it booked in.
    If it needs replacement, are the parts readily available or will it be off the road for a while??
    should be overnight max....they can 'V.O.R.' in any bits overnight
    Merseyside
    Thanks for that - going to see what it sounds like this morning. Its damp and quite cold outside, so iI'll see what noises it makes on start up. Then I'll go to the stealers and get it looked at.
    Its not long been back out of there after gear lever came apart in my hands...... then there was the seatbelts.....brakes......cruise control......not to mention the appaling headlight beams.....
    Merseyside
    Been out for a drive this morning, and it was as quiet as a mouse on start up. Will keep it for a week or 2 and see what else it does.
  1. Starter motor
    By lencuff in forum Y & Z30DT Specific
    Last Post: 9th January 2013, 21:09
  2. Starter Motor Replacement 1.9 CDTi 150 Help, very noisy.
    By Chocki in forum Vectra C / Signum Car Chat
    Last Post: 21st September 2011, 17:45
  3. 2.2 dti Starter Motor
    By bobast in forum Engine & Drivetrain
    Last Post: 11th March 2011, 12:04
  4. Starter motor
    By pjabrid in forum Vectra C / Signum Car Chat
    Last Post: 20th February 2011, 22:40
  5. Starter motor
    By pjabrid in forum Engine & Drivetrain
    Last Post: 10th February 2011, 21:18
