Results 1 to 10 of 17
Thread: Nearly killed the old girl me thinks
    Regular Member andymagee1982's Avatar
    May 2008
    Widnes.
    Angry Nearly killed the old girl me thinks
    Well due to some starting problems i decided to change my glow plugs today..
    I took out looking from the front from the rite side plug 1 & 2 and went on the 3rd and it snapped
    the 4th and that snapped to
    So the car starts and runns ok but with some sort of as i can only decribe as tiss tiss tiss v small sound as its running i think the 4th plug is lettin pressure out a little.
    So whats the situation now men??
    Sunny Dartmoor
    You're bu66ered m8,either head off or drill and tap only if you can get all the swarf out of the cylinders,good luck..........
    Regular Member vectragsi3.2's Avatar
    Feb 2007
    cheshire/staffordshire
    as glen said its a new head jobbie
    Full Member Big Sig's Avatar
    I managed to get a sheared off spark plug out with some easyouts before now. just be careful not to drill right through them.
    May 2008
    Widnes.
    As they are glow plugs i will have to snap the top connection off to apply easy outs. But i think this mite cause the glow pice to fall in the block.
    My friend thinks its easy to take the head off and just replace but with new gasket and bolts???
    I have no IDA!
    Regular Member Ste's Avatar
    ..... Driving the Jaguar XF
    Vehicle : Jaguar XF 3.0D V6
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    not too difficult to remove / replace, what's the torque down procedure?
    May 2008
    Widnes.
    update people!!
    I took the car to a local fixers!
    I got the old fffffffffffffff. Gonna be a few quid that son!
    I will work out the cost of parts and labour and call you back with the price.. £600 at least.
    Ye well if its that much i will try myself and if all goes peet i will get a used engine and have someone replace it.
    Away i went---
    I have managed to drill out the old snapped plugs and banged an old screwi into the hole and twist out.
    Would be a good how2. I will write one up i think.
    Job's not done yet i need to replace my Turbo, Manifold and Heat covers.
    Then crank it (with my eyes closed and fingers,arms,leggs and B+@+s crossed) hoping that nothin major has fell in..
    I was also told that if the piston is up and scrap has fell in the engine it will only end up at the bottom of the engine and do no damage as its soft compound and v. small pices. But as most people know if 2 are up 2 are down
    We will see in the next two days as i will be putting it all back together..
    Regular Member ion's Avatar
    walsall
    Good luck mate, hope it's ok.
    Sunny Dartmoor
    Sounds good so far,hope it starts without any problems......
    Regular Member SteveH's Avatar
    Apr 2006
    Wigan
    Just out of intrest Andy is yours a 2.0 or 2.2 DTI
  1. Am I the only one that thinks...............
    By keith1983 in forum General Motoring Chat
    Last Post: 3rd December 2012, 16:59
  2. Am I the only one that thinks...............
    Last Post: 16th November 2012, 23:47
  3. What Do You Thinks Best ?
    By Tam80 in forum Vectra C / Signum Car Chat
    Last Post: 28th February 2011, 19:03
  4. Who Thinks?
    By VauxVeteran in forum Vectra C / Signum Car Chat
    Last Post: 15th November 2006, 05:39
