Results 1 to 10 of 11
Thread: Getting the power down.
    Regular Member EARLEY's Avatar
    Oct 2007
    Liverpool
    Default Getting the power down.
    is there a best way to get the power down with a front wheel drive car?
    My astra can spin in third gear if the aceleration is pushed its pretty easy to be honest boot it from stand still and you dont move much just spin the wheels
    Any tips?
    Nicking Ya Dinner.
    Don't press the pedal so hard next time.
    Jul 2006
    Get it rolling before giving it too much with the loud pedal. Once the wheels are spinning then you can quite easily keep them spinning into 3rd gear.
    I go for medium acceleration in first gear, early change to second then squeeze the pedal right to the floor. Don't stamp on it, you'll just break traction again.
    Nicking Ya Dinner.
    Quote Originally Posted by parapaul View Post
    I'd just drive properly and get 5k more out of my tyres and 5 mpg more.
    Tyneside
    Blend the throttle, easy to do and keep maximum power at all times, just takes fine tuning although I do enjoy just flooring it and spinning them up some times LOL.
    Oct 2007
    Liverpool
    i can take off easy and get it going but thepower is just un controllable at times.
    Presumably, this is the Astra VXR?
    If so, does it not have Traction Control?
    If it does have Traction Control, then compare with it on and off
    If there is no difference then there is a fault
    I used to be able to get my Vectra SRi140 to wheel spin in 4th gear, a quick visit to the dealership and the nearside ABS sensor was found to be displaced, so it was replaced the following day and that fixed the problem
    belfast
    i also have a skyline rwd 360 bhp but first and second gear u have to start of easy
    brumie brum brum
    Quote Originally Posted by EARLEY View Post
    Any tips?
    Moderator edit due to lack of respect and tact.
    Regular Member satbeychap's Avatar
    Devon
    In the Westfield i can spin the wheels in any gear at pretty much any speed in the wet, up to 4th in the dry. Best to get it nice and straight, put the power on slightly 1st and then floor it, doesn't jolt the wheels as much if you catch my drift?
  1. Replies: 17
    Last Post: 11th March 2015, 00:55
  2. Signum Sluggish low power, Limp mode at high power.
    By Bigg943 in forum Troubleshooting
    Last Post: 6th June 2011, 18:55
  3. Signum Sluggish low power, Limp mode at high power.
    Last Post: 5th June 2011, 11:30
  4. Replies: 11
    Last Post: 7th January 2010, 17:50
  5. Power Steering Electrical Power Drain
    By AntB in forum Suspension, Wheels & Brakes
    Last Post: 1st November 2007, 16:03
