Thread: Knocking Noise When Turning Wheel
    Sligo - Ireland
    Default Knocking Noise When Turning Wheel
    Has anyone had this problem?, if the car is idle and you turn the stering wheel there is a knocking noise coming from the front passenger wheel?
    knocking when steering points to any of the swivel points.. so it could be....
    inner jack arm joint
    trackrod end joint
    bottom ball joint
    top strut bearing..
    the only way to find out is to check for wear in all these joints..
    Regular Member Hummelshøj's Avatar
    Aug 2009
    Denmark, Kolind
    Vehicle : Vectra C OPC Estate
    Trim : OPC / VXR
    Engine : Z28NET
    I have this on the drivers side..
    Top bearing and consol changed
    Bottom balljoint/wishbone changed
    Complete new drive shaft changed
    What is "inner jack arm joint"?
    Regular Member nikroc's Avatar
    Nov 2007
    DERBY
    17 Post(s)
    Vehicle : 2t
    Trim : standard
    Engine : z20net
    Year : 08
    Mileage : 32000
    Droplink maybe?
  1. Noise from F/O/S wheel when turning left
    By hothatch in forum Suspension, Wheels & Brakes
    Last Post: 9th January 2013, 23:24
  2. Knocking noise from Front Wheel
    By lostdog in forum Vectra C / Signum Car Chat
    Last Post: 20th November 2010, 08:14
  3. Clonking noise heard when turning the steering wheel
    By Big Dave in forum Suspension, Wheels & Brakes
    Last Post: 15th January 2010, 02:40
  4. Front bang/knock noise on turning wheel
    By NPS in forum Suspension, Wheels & Brakes
    Last Post: 14th January 2009, 19:58
  5. 4 Wheel alignment and knocking noise
    By man on the moon in forum Suspension, Wheels & Brakes
    Last Post: 21st August 2008, 23:23
knocking noise when turning on vectra c
vectra c knocking noise steering
vectra knocking noise when turning
vectra suspension noise turning wheel
slight knocking noise when turning steering wheel vauxhall signum
vauxhall signum noise when turning steering
vauxhall vectra knocking noise from front
knocking when turning vectra
vectra c noise when turning
