Thread: changing plugs
    Feb 2007
    GREENOCK
    Default changing plugs
    got a 55 plate sri 27,000 miles should i change the plugs? how much for plugs and what is the best to get. thanks
    Nicking Ya Dinner.
    VX ones, about £4 each iirc.
    And yes change em every 20k, I know the book will say different, but the book is a repmobile pleaser.
    Feb 2007
    GREENOCK
    Are they easy to change do yo have to set ant gaps or are they all done?
    Nicking Ya Dinner.
    Should be pre gapped tbh, as for changing them I've not done a set myself on that engine, but iirc all you do is remove the centre strip off the cam cover, pull the spark pack up and undo the plugs, might need a 5 inch extention for your wrench though, and try to turn the new ones in by hand most of the way, and only tighten until you feel it bite, alloy heads don't like overtightening, hth.
    Regular Member johnmac's Avatar
    Apr 2006
    Inverclyde
    Jun 2007
    Black Country
    this is an old tip i was given years ago
    when replacing your new plugs, fit 12" of hose pipe over the end of the plug, when you turn the plug into the engine, if the hose slips, the plug is cross threading, you can still feel if the plug is seated correctly
    saves a lot of aggro
  1. Changing spark plugs 2.8T
    By gibbon7000 in forum Engine & Drivetrain
    Last Post: 14th June 2012, 12:28
  2. Changing Spark Plugs
    By Chris SRi in forum Vectra C / Signum Troubleshooting
    Last Post: 7th October 2011, 21:50
  3. Changing plugs on 1.8
    By PeterVV in forum Vectra C / Signum Car Chat
    Last Post: 27th February 2008, 23:59
