Thread: Z16XE problem
    Jul 2006
    Question Z16XE problem
    Sam's just changed her Mini for an 02 Astra with the Z16XE engine. It was (apparently) serviced by the place she bought it from, but just wondered if anyone could shed any light on this...
    On starting the engine (both cold and and warm starts) it turns over perfectly, but about a second after it starts, the revs drop to less than 500rpm, all the interior lights and dials dim, and it splutters as if it's going to stall.
    The only light that comes on is the yellow rectangle with a star inside - haven't got the manual to hand but I have a feeling it's the coolant level warning. No battery light, nothing else at all. This only happens for a second or two, after which the engine seems to catch up again, and runs perfectly well.
    I haven't had a chance yet to get my head under the bonnet, but I would assume, seeing as it runs fine the rest of the time, that all the fluid levels are OK. It's not a major problem, I just don't want the car to flake out on her the first time we have a cold morning.
    Anyone?
    sounds like a dirty idle valve if it dips down that low...is it only when it starts that it does it?.. does it idle fine all the rest of the time?..
    Part of the cars startup procedure is to raise the RPM via the ICV while it's on 'cold start' procedure... it may be flooding it with fuel and the idle valve still wants to open up further still..
    Jul 2006
    Yes, only on startup, it idles fine once it's running. Is the idle valve reasonably easy to access, remove and clean? The car's still got a few months' warranty from the garage we bought it from, but the engine looks quite strightforward compared to the computer-addled V6 lump in mine
    Jul 2006
    Something else to throw into the mix - I've just been told that when she was driving to work this morning, when lifting off the accelerator the car 'kangaroos' as the revs drop. Sounds like it could be a related problem?
  1. Rear Signum Light problem problem - help
  3. 1 problem sorted and 1 more problem arises
    Last Post: 4th April 2011, 13:03
  4. Problem...? Vectra SXI...problem with starting after filling with fuel?
z16xe kangarooing
