Thread: battery charge light
    Nov 2007
    lancashire
    Default battery charge light
    just put on a cam belt on me 1.9 cdti, i fired up the motor without the alternator belt fitted to see how she sounded when i noticed that the charge light went out with the engine runing. how can this be with no alternator belt on???????
    Regular Member Ste's Avatar
    ..... Driving the Jaguar XF
    Vehicle : Jaguar XF 3.0D V6
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    Magic?
    Nov 2007
    lancashire
    yeah cheer's ste you wit and knowledge knows no bounds
    Nov 2007
    lancashire
    come on boys this has happened before to other people someone must know.
    N. Ireland
    it only comes on when the battery is going flat, run it for an hour with the lights, radio, rear window heater and a few other things going and it willl soon come on if its not getting a charge
    Nov 2007
    lancashire
    so this means it is not a charge light at all, it is a battery condition light.
    This is the first car i have ever heard of that does this,anybody else got a more convinsing theory on this???????
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    Nope, if it was a battery condition light, then why does it illuminate before cranking the engine at ignition position II
    N. Ireland
    Quote Originally Posted by Ste View Post
    why does it show airbag light, abs light, tc light etc before cranking?
    Oct 2006
    Waterloo, Liverpool
    8 Post(s)
    Trim : SRI NAV XP
    Engine : 1.9 CDTI 150
    Mileage : 72K
    Quote Originally Posted by jaxouk View Post
    Carrying out diagnostic checks on ignition start up, on those electronic aids, which are monitored by sensors. All modern cars do this.....and more. Quite normal. If those lights stay on and don't go off when you start the engine, a problem has been 'sensed', and requires investigation.
    Nov 2007
    lancashire
    Quote Originally Posted by john_k_sri View Post
    yes agreed so why whith no alternator belt on does the light go out when you start the car, if the light came on that would point to a problem but the light goes out which normally points to a normal working system.
    confussed???
  1. Battery not holding charge
    By Froggy in forum Electrical & ICE (including SatNav)
    Last Post: 7th February 2013, 15:21
  2. Replies: 4
    Last Post: 18th August 2012, 08:58
  3. Battery Light ON - 14.1 volts at battery
    By snapsnap in forum Electrical & ICE (including SatNav)
    Last Post: 6th December 2011, 13:55
  4. Battery Has charge, Car won't start.
    By Vectra_C_Chris in forum Electrical & ICE (including SatNav)
    Last Post: 5th May 2010, 10:20
  5. battery wont charge!!
    By manghan in forum Engine & Drivetrain
    Last Post: 28th March 2010, 11:48
vectra c battery charged but ignition lights go off
