Thread: light
    Regular Member willoftoon's Avatar
    FOREST HALL NEWCASTLE ,,,,,OR DECKHAM ,, ON SUNDAYS .. DINNER TIME MAMMY,S
    Default light
    spanner light comes on when i start car when left over night or a couple of houtrs then goes off after a minute or so been told sound like glow plugs if so much are they and how many are there .. 1,9 cdti..
    Regular Member Stu14t's Avatar
    Perth, Scotland
    I think, and I may be wrong, there are 4 of them and if you pull the plastic cover off the top of the engine they are under the common rail
    Ask DeanF I think he has done it. Not too hard.
    Glasgow
    Its not the glow plugs it means your car has a fault stored i learned from the manual ignore it unless it comes on whilst driving. As long as it comes on with the ignition and off when you turn it over dont worry about it.
    Full Member Big Sig's Avatar
    get the codes read.
    comes on with ignition and goes off after a few minutes .. never used to do it but if i drive it a while then turn it off say for a few minutes then on again it comes on then straight off as soon as i drive away
    Regular Member andymagee1982's Avatar
    May 2008
    Widnes.
    Be carefull I snapped two inside the block today on a 2.0DTI
    By Shadrack in forum Vectra C / Signum Troubleshooting
  2. Replies: 4
    Last Post: 18th August 2012, 08:58
  3. Replies: 17
    Last Post: 16th August 2012, 10:07
  4. No throttle, traction control light, engine management light
    By si260188 in forum Engine & Drivetrain
    Last Post: 9th May 2010, 21:45
  5. Fitted rear light,illuminated sunvisors and map reading light
    By glenboy in forum Vectra C / Signum Car Chat
    Last Post: 30th March 2008, 10:51
