Thread: Additional lights
    Stockton on tees
    confused Additional lights
    I have a Vectra 1.9 tdcfi and am installing aux lights which I want to wire to my sidelights does anyone know which colour wire is the one to join to? I am just going to use scotchloks. Robmc
    Here, there and every where!
    I wouldn't if i were you or the CANbus system will throw up an error code due to the current draw being affected.
    With the Veccy you can't just splice into wiring like a normal car m8. Most of the electrics are signal not voltage
    Stockton on tees
    Default help please
    Thanx for that only had a veccie 3 weeks so don't know/understand canbus whats the best way to connect additional lighting so it comes on with sidelightsm or headlights??????
    Sunny Dartmoor
    Maybe take a feed from the ciggy lighter...........
    Quote Originally Posted by rob mc View Post
    http://www.bba-reman.com/content.asp...otive_industry
    Fitting relays so there will be very little current drain made on the headlight/sidelight circuits maybe?
    Stockton on tees
    Question worth a go?
    yeh thanx just reading thro How 2's etc thought maybe wiring through a relay worth effort, but still need to know wire colours for side light or headlight n e ideas?
    Full Member Big Sig's Avatar
    Dunno, I would try it and see what happens, but would also suspect a bulb warning light to come on or something similar
  1. Additional Lights in Boot - WEIRD problem
    By NealM in forum Electrical & ICE (including SatNav)
    Last Post: 14th March 2011, 13:03
  2. Additional switches
    By chris_20 in forum Vectra C / Signum Car Chat
    Last Post: 25th September 2010, 00:43
  3. Additional gauges
    By greg_t in forum Vectra C / Signum Car Chat
    Last Post: 8th February 2009, 18:51
