Thread: No 1st gear!
    Rotherham
    Default No 1st gear!
    Hi All,
    I've lost first gear! Tried to put it into 1st after reversing and it wouldn't go! It would just pop out when I lifted the clutch. If I kept the lever pushed towards 1st and lifted the clutch, it would grind and just pop out again!
    Any ideas what the problem is?
    Thanks in advance.
    it could be linkage?.. if it's only partly engaging the gear, then when you apply the power it will always pop the gear out...
    if not, it's going to be rather serious and expensive......
    Rotherham
    Thanks for the swift response. It's a company car, so hopefully it shouldn't cost me anything. Unless they accuse me of misue and abuse! The car has done 24,000 miles, most of which are on the motorway.
    throw it at the dealers....
    the boxes are strong.. misuse won't cause that easily..
    Rotherham
    The dealers called me back to inform me they are putting a new gearbox in. They mentioned that it was an internal fault, and as it's a sealed unit they will replace the whole thing. 11 months old and 24k miles = a new gearbox! Thank goodness I'm not paying!
    indeed.....
    must have been a shot selector then.....
    gone are the days of having to do a box on the bench.. now they just swap em..
    Regular Member Ste's Avatar
    ..... Driving the Jaguar XF
    Vehicle : Jaguar XF 3.0D V6
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    And they get centrally re-manufactured as warranty replacements.
  1. cdti stiff gear change, removing gear turret?
    By IrishVectra in forum Vectra C / Signum Car Chat
    Last Post: 17th July 2017, 03:14
  2. Gear lever,gear selector
    By jodiexii in forum Vectra C / Signum Car Chat
    Last Post: 22nd January 2013, 09:43
  3. Reverse gear - weak spring on gear stick
    By Dal5band in forum Bodywork & Interior
    Last Post: 20th December 2011, 13:18
  4. Stiff gear change, gear selection fine though
    By tramman in forum Engine & Drivetrain
    Last Post: 24th November 2009, 23:20
  5. Vec C 52 plate 2.2 Dti Gear Stick Jumps out of 1st gear on take off
    By ukwanderer01 in forum Engine & Drivetrain
    Last Post: 5th July 2009, 21:43
