Thread: engine code on 2.0 turbo vec c?
    St Neots
    Default engine code on 2.0 turbo vec c?
    what is the engine code for the vectra C 2.0l turbo (prefacelift)
    i know there are loads of different codes z20let lel leh etc etc.
    is there the same amount of performance tuning products available for this engine? bigger turbos, fmic etc etc?
    thanks
    Regular Member pricey's Avatar
    Dewsbury, West Yorkshire
    iirc it's the Z20NET in the Vectra.
    Tyneside
    As above mate
    St Neots
    and what tuning products are available?
    Tyneside
    BSR are at the fore front with the 2.0T, a few guys including myself are running stage 3 which should see close to 250Bhp and 280lb/ft. Stage 1 up to 220+Bhp and around the 240lb/ft mark.
    Stage 1 is a remap and stage 3 is another remap, injectors and turbo back exhaust. With stage 1 it can be put on and taken off when you want as the PPC gives you this ability.
    Stage 1 - £568 and stage 3 is around £1200 if you already have stage 1 or £1700 from standard. The cost is due to the PPC which as already mentioned allows you to run it standard or remapped when you want
    BSR
    St Neots
    lovely cheers mate
  1. 2.0t turbo fault code P0034
    By loonyone in forum Vectra C / Signum Troubleshooting
    Last Post: 6th May 2018, 21:08
  2. Engine code
    By dti owner in forum Vectra C / Signum Car Chat
    Last Post: 10th October 2012, 23:01
  3. Fault code P0243 (1.9CDTI 150) Turbo wastegate...
    By danBoy in forum Engine & Drivetrain
    Last Post: 4th December 2010, 15:45
  4. engine code for a 1.8 vvt
    By Dougb in forum Engine & Drivetrain
    Last Post: 24th July 2010, 18:04
  5. engine code
    By cbl1985 in forum Engine & Drivetrain
    Last Post: 8th January 2010, 21:50
vectra c 2.0 turbo engine code
